Solid Audio 1500 watts Class D
Hello!
Good Day! I have solid audio 1500 watts rms does not have an output. This amp is not in protect state.
I replaced with a new HIP8040 driver but still no output. I have +-12V into op amps. I have a rail voltage of +70Volts.
IC HIP4080 Voltage reading
1. 12
2. 13.4
3. 13.4
4. 0
5. 6.7
6. 6.5
7. 6.6
8. 6.2
9. 5.7
10. 12.9
11. 10.3
12. 10.4
13. 0
14. 0
15. 13.4
16. 13.4
17. 0
18. 0
19. 10.4
20 10.4
Thank you so much! and more power!
The pot is DC offset on similar amps.
Is the red LED lit?
Is the white LED green, red or unlit?
sorry I can't distinguish RED or GREEN, Im a color blind person.
The LED lit on power side and not the protect LED. There is rail voltage and opamp voltages.
During a cold boot, there some thing scratchy noise that you can heard...after a while it gone. then silent...
If this amp has 470K ohm pulldown resistors on the output transistors, you can power it up without the 4080 in the circuit. Does pin 3 go low without the 4080 in the circuit?
Has anything else been done to the amp besides replacing the 4080?
This amp was junk for more than a year. I found some rusty component such capacitors. Yeah without the HP4080 the amp still powered up. I will measure the pin 3 and get back to you.
