First One - mosFET amplifier module
I'm sorry, my previous post post wasn't exact.
My (not so) old LM3886 was sitting on a shelf, now back in use.
The measurement I did ( 1 Volt peak to peak input voltage from my DAC preamp ) was done with another amplifier, with a 17,5 factor gain.
Giving a large enough amount of power for my sound system.
JM
OK, to be more precise, I just pulled my oscilloscope and made some measurements with my LM3886 amplifier.
I'm under 1 volt peak to peak input (from my DAC preamp) and a maximum of 40 volts peak to peak output to keep my ears safe., :)
Is this feasible with the 1.4M module, and my present voltage rail ?
JM
JM
Your ears are on the safe side since FO M has +27,75 dB of voltage gain. ;)
50 Volts pp will be more than enough according to what I just measured.
Will you make the resistors mods yourself ?
JM
Done. ;)
Calibrating my modules ...........
Hi !
I received my 2 FO 1.4M modules a few days ago.
It took me some time to install the 1st one on its radiator.
Now I've been trying to adjust the 0 Volt offset no problem playing with TR1 and TR2.
The problem is the voltage I get between TP1/TP2 and TP3/TP4 : I can get the same 21,80 mV on each side, and O volt offset,
but never the 180mV you mention on the 1.4M manual.
Is this somehow related to the mod you've done on my modules
(adjusted to my 30 - 31Volts to be precise) rail ?
Thanks ......
JMK
Good news
I've been very coutious installing the 1st module in my chassis previously used with Lm3886 modules in a dual mono configuration.
I left the LM3886 on the right channel, and installed the 1st FO 1.4M on the left channel.
It took me a while to properly calibrate it, it will be easy for the next one !
My left channel is MUCH BETTER than the LM3886 channel, specially in the mid/bass range.
I must say that my big floor standing 3 ways speakers are pretty dificult to drive properly, and it looks like it will be excellent - but still some work to do to install the 2nd module.
More details in a couple of days !
Cheers
JMK
Hi Everyone,
in the past days I had the chance to test my dual FO 1.4M with 2 smps from audiopower.it version DPS-400/S1 and I thought I could share some info and picture.
I knew this supply from a previous project 2 years ago, and till then they have revised this smps with a new transformer and the overall power is said to be supporting 600watt and more than 600ma continuous current (bias) wihout any overload problem.
I wanted to keep the overall temperature of the amp below 50°C and then I have chosen a 2x52V version, which is 10V less than hypex, so the overall dissipation (without signal) is 29watt per heatsink instead of 35watts, reducing the heatsink temperature of about 3 degrees.
The result is amazing good soundwise. with the 2 smps, obviously the result is better than with 1 big hypex!. I can hear more séparation across the 2 speakers. for the bass, it is a mater of volume listening.
the SMPS is quite compact (105x105) and can be fixed on a standard 2U 300x80 heatsink, with the FO.
the only drawback I see is that the supply do not have the posibility to directly connect a DC current protection (as sold by LC) as its standby mode is not "latched" so if your concerned by DC protection you have to add a traditional relay based protection.
here we are with another alternative to make compact dual mono system, for example using the "mini dissipante" case.
