Not wanting to repeat myself but at high frequencies diffraction can give resonance a run for its money.Anyways, directivity will be a big factor here and the non-stereo set-up won't tell all the story.
@ jcga (and others)
If you feel the RAAL 70-20XR is unusable below 4khz even with 24db/oct slope, you really should contact Aleksandar Radisavljevic about it.
Why?
The distortion curve is pretty much what one would expect from any ribbon tweeter and is echoed in the THD curve of the 70-10 I found elsewhere on the webs.
Updated list:
Beyma TPL-150 (air motion)
RAAL 70-20XR (ribbon)
Airborne RT-4001 (air motion)
Visaton TL16H (compression horn)
RAAL 64-10 (ribbon)
Tlab N26CFR-A (dome)
Can we all agree this dome is a good start?
http://solen.ca/wp-content/uploads/n26cfra.pdf
i heard they are as good as the Scan-speak if not better, but cheaper...
RAAL 64-10 (ribbon)
Nah,
It's not sure woden carbon has any advantage in rigidity and weight at these low Sd !
Btw, despite the above discussion about where treble start in relation to the planar drivers (ribon, etc,), I believe a good test is the Triangle : it starts at 2000 Hz and stop around 17 000 Hz! (Frankly, the only serious reason to start a tweeter at 4K is to leave the piano which can have fundamental up to 4k Hz...if only you're a piano lover! For human voices it's a lost cause if you want to go Full Range !
Because the competitors, why not taking if you can the small Be from ScanSpeak ? or a Satori from SB ? And yes why not the Peerless (if it can live with a XO as low as 2000 Hz)!
Updated list:
RAAL 64-10 (ribbon)
If i were to choose a low-cost dome, that is among the best recognized value... Any suggestions ?
XT25BG60 will be on the list.
Speaking of threshold... i think we need some backup, you know in case the midrange story repeats itself ?
how 'bout that one:
GRS 1TM-4 1" Mylar Tweeter 4 Ohm
how 'bout that one:
This tweeter has an interesting diffraction horn to control directivity and is used by Bruno Putzeys in his Kii speaker.
https://www.madisoundspeakerstore.com/horn-tweeters/seas-prestige-27tbcd/gb-dxt-h1499-tweeter/
So it should be pretty good. Can't be used without FR-compensation by design.
- World's best Tweeters Blind Testing
