Nice work... I made some changes on circuit...
Good afternoon.
Could provide the scheme?
Thank you.
what is this component? R120
MUR120 diode.
APEX SPS1K v1.2
Hi,can you post this in black&white for home etching?
As far as I can see there is no artwork change between v1.1 and v1.2. Only the values have changed.
Sent from my HUAWEI MT7-L09 using Tapatalk
What is the difference between v1.1 & v1.2 of SPS 1000? is there an up-to-date schematic available? I ask caused I have just about recovered my work area and want see what components I need to source
there is between v1.1 & v 1.2
on RED marked Part changed, & on GREEN marked track changed by Apex.
here it is,
regards
APEX sps1k sch
Trafo winding by Apex:
- Use 0.6mm wire
- Wind 20 turn with 4 x 0.6mm wires in parallel on ETD49 for primary
- Wind 3 turn with 0.6mm for 24v secundary and 2 turns 2 x 0.6mm in series for 2 x 15v
- Wind 2 x 8 turn with 5 x0.6mm wires in parallel For main secundar.
- Use 0.6mm wire
View attachment 563021 there is between v1.1 & v 1.2
Track for 15v gnd must be reroute.
That is what I used to begin with bu there a several differences to the PCBs.
my amplifier. Now it works, I repaired
Nice work, what is core material with this big gap? BD241 must have heatsink.
I install the heat sink, I do not have it, I need to buy. Material 2000NM core, you can put a ring on EPCOS. The size 45*28*12
- Class D
- Class D Amp with LM566, LM393 and 2XIRF530
