Thanks Lo is there a particular booster for the adapter I linked. I doubt I'd need one, but curious.
I ordered the one that JimBeam69 posted a link.
It's very simple:
-this Particular Booster already has a 2.1x5.5 mm DC Input Jack, so you can just plug your Power Adapter in there
-the output terminal(labeled "out") can be wired to this DC Plug DC Plug on aliexpress, which can be directly plugged into your board.
Theres one Blue Potentiometer(v-adj) to adjust the Voltage, you need a Multimeter to set it to the voltage you need. The Other Blue Potentiometer is to adjust the maximum Current, it should be set to max.
Here's a youtube review about this particular step up converter:
600W DC-DC Boost Converter Review and Play Around (This one's a keeper)
My experience with all three types of TDA7498 boards i have used is that they work great with anything from a 19v laptop brick up to a 36v smps (meanwell knockoff).
Two 12v sla batteries gave me the most satisfying results.
But i had a 19v laptop brick that wasn't able to drive the board.
Voltage broke down completely when poweing the amp up.
That might be because of the 4700uF chemicon kzn i put in front of the power input....i do not know, just a possibility.
More than just a possibility...That might be because of the 4700uF chemicon kzn i put in front of the power input....i do not know, just a possibility.
Will this work guys or are the amps too low? https://www.amazon.com/SMAKN®-110V-...8&sr=1-1-catcorr&keywords=36+volt++ac+adapter
One of the reasons to choose a TDA7498 is that it can deliver ~50W/channel before distortion starts creeping up. To do that, it needs a ~36V supply, which that is. But that 36v supply needs to be able to deliver >100W, which the one you linked to makes no claims of being able to do.
So, yeah, the amps are too low.
So these are the 2 I'm looking at. Like I said I'm on a tight NY budget, so one of these will have to do. So which one will give me the most power, easp/jerms?
https://www.amazon.com/gp/product/B0150ZYHOO/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A2OCOGC9B25845
or
https://www.amazon.com/gp/product/B01H50J0NA/ref=ox_sc_act_title_6?ie=UTF8&psc=1&smid=ARVS18RS1K4U1
Jerms I already have a Dayton 1200 sub that I can use.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
or
Hi easp these are the speakers: 8 ohmsRemind us about the speakers you plan to drive? Impedance?
HVL-1 Bookshelf Two-Way Loudspeaker | Wave Crest Audio
- Class D
- Ebay cheap TDA7498 boards
