Valve Itch phono
Joined 2009
Noted is EC8010's #2
Salas my signal generator has an output of 600 ohms how to scale 22R for 75R oscillator or 47R for 50R oscillator?
use a very 2 stage measering amplifier - high Z-in and low Z-out - and place the inverse RIAA between the 2 stages. It should not be impoosible to make such an "Inverse-RIAA-measurement-tool" with low noise and low distortion op-amps like AD 7xx series.
This is all you should know to do this - it's only using of basic design principles and good measurement tool like ARTA.
