Class D Amp with LM566, LM393 and 2XIRF530
It's a ETD29 .
Changing the 510R up to 4k7 i can't see anything higher than 350 KHz.
At 350 KHz the measurement remaining oscillation after Low pass filter is 900 mV RMS.
Isn't possible to play well at 350 Khz. When volume is low everything is ok but increasing the volume amplifier crackles and stops.
Putting the 510R in position again everything seems to be ok.:confused:
my d200 is working very nice in low volume,
but i also have that cracking sound i can't play in loud and i dont have oscilloscope i cant see what is happening so i just try to copy the gate resistor of other amp with irfb4227 they using 10r so i copy and replace the 47r with 10r and it sound louder than before but i can still hear the the crack in heavy bass my amp is louder than before now hoping experts can try this nice sounding amp and improve or fix some issue
If you need a micrometer to measure it, then it is too thin. It should be close to 1 mm. (And of course more turns.)
Saturation current=250A*air gap (in mm) / turns. For example 20 turns with 0.2 mm gives only 2.5A
Pafi,i haven't a micrometer but i have an LCR Meter.Look this measurement.
