Great thing that SMPS has made such improvement (flexibility to handle power line uglies, not that most are any better about being a "nice" load).
Only if it has a good PFC chip at the front end.
(had'ta get another acronym in there).
John
Ed,
with a 1000 foot cable, use a step function and a resistive load ranging from 4 to 150 ohms.
The settling time to 95% value will surprise you.
Also, the cusp at the cable impedance.. there, it'll be the transit time, 2 uSec.
John
No it really won't which is why I went to twinax with Zobel terminations. They over ran the test batch so I have 2,000-4,000 feet extra, will know for sure after they finish pulling cable.
Right now working on heterodyne filters for the switching audio power amplifiers.
No it won't what?
The only thing a zobel will do is damp out reflections as the speaker unloads at HF. While the speaker is pulling power in it's low impedance range, the zobel does little.
You have to resist trying to satisfy the TDR with a zobel at the far end of the cable. That has little bearing to the settling time of a 4 ohm load on a high z cable. It will however, protect the amp from oscillation as the speaker unloads at higher frequencies below the unity gain point of the amp.
If you really want to learn what is happening, use a step function and vary a resistive load at the far end. As I said, you will find the settling time rather interesting. Or, you could wave your hands at the moon.
John
seems that your ac utility companyy allows heavy loading of their transformers.....keeps costs down, I suppose.
It seems so.
Add that heavy loaded transformers intended for working close to their magnetic saturation achieve very good voltage regulation.
Mostly loading on the distribution transformers.
Thanks. I meant if there is a problem with the audio equipment’s transformer.
George
No it won't what?
John
No the settling time won't surprise me. If I get the chance I'll post the oscilloscope shots.
The cable is not a high z cable. It took a bit to get through to the cable folks why I wanted certain features.
I only wave my hands at the moon during festivities when there are naked women dancing.....
I again look forward to scope shots with no axis information, no conditions, no schematic, no verbage explaining what you did...No the settling time won't surprise me. If I get the chance I'll post the oscilloscope shots.
It shouldn't be difficult to design a specific cable with specific impedance with specific shield, or specific twist pitch. If you don't specify, you get what you get.
As to specific impedance of twinax, the shield alters only the hf impedance magnetically, and lf impedance only by capacitance.
That's a great example of the misapplication of perfectly good hands..I only wave my hands at the moon during festivities when there are naked women dancing.....
John
The attached .wav file (inside a zip archive) may help. It's a 230V, 50Hz sinewave with flattened top. Amplitude adjusted so VRMS is still 230V. LTSPICE total harmonic distortion (@ 1usec transient stepsize) is 5%.
That's the part I was missing. Serves me right for trying to do 3 things at once.
This was my approach to a power a clean AC power supply.
what is the transformer spec?
-Richard
-Richard
It was from this line rated 20 amps 125 volts.
Power Conditioning | Plitron
While I like the concept, the op amp outputs will be very susceptible to destruction if the opamp power rails fall below the secondary voltage. You'll forward bias all the tubs on the chip. The turn on sequence is very important.This was my approach to a power a clean AC power supply.
I suspect a transient spike can do that, so a good suppressor on the primary would be important.
John
John
Opamps establish the balanced power ground. Not sure how you think they will ever see the 84 volts output.
Running for better than 5 years.
Please examine your circuit again.
John
- Member Areas
- The Lounge
