DC Servo MOSFET Amplifier
looks good.. 100N filter missing ;)
The 100n caps are SMD. Notation is in red and reversed because it is on the bottom. I guess I could move things over so I can add through hole parts too.
Originally Posted by still4given View Post
I took a stab at a layout for the balanced input. Please check it for accuracy.
Thanks, Terry
DO NOT!!! ne5532!!! BETTER ad843-5+ad817-811!!
Are you saying Mile's design is not good? Better to argue that in the other thread.
Mr. Miles can I put one more pair of IRF mosfets to the 3 pair dc servo mosfet amp (so total 4 pairs) and use 77VDC supply? is there any need for changing the small signal transistors? what would be power in 8 ohms and 4 ohms with 77VDC supply?
also can use the FX-100 supply for PSU and protect function for this 4 pair amplifier ?
link for amp and supply here...
amp: http://www.diyaudio.com/forums/solid-state/162081-dc-servo-mosfet-amplifier-54.html#post4567321
supply: http://www.diyaudio.com/forums/solid-state/162081-dc-servo-mosfet-amplifier-61.html#post4624521
