Let me be more specific (though you perfectly understand what I mean...):
when an output coupling capacitor is required (to block DC and this indeed depends on the output stage configuration) then the 3000 uF would be needed to ensure LF bandwidth.
It is obvious. The same way, like low inductance of a plate load transformer primary can be used as a HPF.
PS: it is an OT. Let's ask the moderator to move "OTL, not OTL, & Matching VS Loading transformers" into a separate thread?
In any case: scheme please!
Later; when I am sure it is repeatable, and does not need thorough fine tuning.
Wavebourn , did you post the Hybrid Schematic?
- Tubes / Valves
- OTL, not OTL, & Matching VS Loading transformers
