I heard the SM75-150S isn't available anymore. So what is the difference between the S and the non-S version? Is it mainly sensitivity? I've seen Shin's measurements of the SM75-150S and the distortion levels are very impressive, and I wonder how the non-S version compares?
From what I have read, the only difference is the sensitivity increase for the S version. The cone assembly is the same for both (the same recone kits work for both versions). If you look at pictures of the units, the S version has a much bigger/stronger magnet which provides the sensitivity increase.
Cheers
Cheers
One has to wonder then, why ATC use the S version even in their active speakers where sensitivity is not an issue, and also in their passive ones with low sensitivity.
I did email ATC to ask the difference, but I guess they are on holiday at the moment since they haven't replied for a couple of days.
I don't think there is anything fancy really: the S version has a stronger magnet, that results in more efficiency in the highs (higher mass break frequency), that's pretty much all there is to it.
http://www.solen.ca/pdf/atc/sm150.pdf
http://www.solen.ca/pdf/atc/sm150s.pdf
That looks very similar. We could just cross the tweeter a little lower to get more detail in the lower highs. I don't know. :S
But where to find them for cheap?! On a students budget I will only afford one. Called ATC in the UK and they wanted ~300 pounds for it.
Oh, and ATC is keeping the S version to their own speakers now, I asked them on the phone. So this discussion is pretty fruitless.
I am planning to use my single, mono SM75-150 driver to build a ATC SCM50 clone to go with my Krell KSA-100 clone, of which none is of course completed. I happen to have the chinese made tweeters from the ATC SCM16A (still on ebay for $21: "atc tweeter") and a pair of unknown ATC PA75-260 STD 8 ohm (!). Not the -314. Not the -243. Not the -234. But a rare -260. I measued also. 255mm across. It likes to be between 250Hz and 900Hz. They are very revealing. I played it a long time before they loosened up a bit, or my stereo warmed up properly. I was scared the first two days and thought, "what a crappy speaker I bought!" We will see if I can decide on a cabinet for these rarities. 255mm is not 243mm across, like in the original SCM50.
I asked ATC and they didn't have anyone old enough to answer what they were. Does anyone here know? I need to know things like cabinets, and if the official scm50/100 crossover still works.
I know I am kinda hi-jacking the thread, but it is on the topic of using the SM75-150 in a sensible way. And since nobody can really buy the S version anymore we could just talk about my speaker project instead. ^^,
Solen will sell you both version, but they are more expensive than direct buy from ATC.
I find the price quite right compared to compression drivers and horns...
True, true. Good compression drivers are equal in price. It is not like I have to buy the worlds best speaker more than once.
It is interesting that you mention compression drivers. Maybe the SM75-150 is considered to be a compression driver, but I am thinking more of TAD, JBL, BMS, etc, when I think of CDs. How would they fare against the SM75-150? The Avantgarde Trio is considered by many, not all, as one of the finest speaker in the world.
I could provide impedance curves of my units (non-super, 16 ohm). Let me know if that's useful. You can easily determine the TS parameters from this.Does anyone have T/S data for SM75-150?
That would be helpful, thank you!
- ATC SM75-150 versus SM75-150S
