Ultimate Open Baffle Gallery
from measurement of course, 90deg measurement usually shows easily.
those are like 95-98db speakers from 30cm so not much power going in
so quess how bad that bms is 3meter when 1-20watts going in
its like vuvuzela
So... Stage one. I had some Markaudio CHR-70's lying around for a build, but then I heard some OB speakers. I promptly turned the build around and switched to OB, after reading here that the MA's could be paired well to the Eminence Alpha 15a. I picked up a pair of Alpha's, routed some holes (loosely following Martin King's papers) and installed the lot on a base. So far, so good.
IMG_4860 by ctjr, on Flickr
IMG_4861 by ctjr, on Flickr
Anyway, now it's time to find a good solution to drive the things. I don't really want to go passive (big $$$ for components, limited flexibility), nor want to have to connect two amps and a crossover... So the hunt is on for a good amp with a build-in filter.
And talk about commercial dipoles, how about these fanatical duo turning them into successful business. Made by CNC from aluminium block!
Oozing quality! And the drivers are off the shelf like ScanSpeak and Acoustic Elegance.
Read the whole experience of buying them dipoles! You need spare $70k I think :)
greghumphries.com/page22/files/cea521e6fa8cbd15d7269608f7e0031c-68.html
btw. no commercial interest here although I know Lee and that guy with smirky smile was my old boss :cool:
