"MUSIC, formerly known as Music Group, a holding company encompassing Behringer, Midas, Klark Teknik and, most recently, the TC Group portfolio of pro audio brands, has announced its proposal to dismiss around 70 staff members at its manufacturing and office facility in Coatbridge, Scotland. In this event, the facility’s Tannoy loudspeaker production efforts will be transferred to MUSIC’s new manufacturing plant in Zhongshan, China; research and development as well as marketing activities will be relocated to MUSIC’s Manchester, UK offices. Approximately one year ago, Music Group acquired TC Electronic, TC-Helicon, TC Applied Technologies, Tannoy, Lab Gruppen and Lake, which comprised the TC Group. Tannoy has been based in Coatbridge for over 35 years. "
www.hifisonix.com
Joined 2003
I would (and have proposed elsewhere ) that you use conventional OPS bias comp schemes for 1st order correction and then a uController for 2nd order correction.
I have currently settled on using conventional comp + NTC to provide a 2nd correction curve at higher temps.
Either of these two approaches offers very tight Ibias compensation.
Seems using a controller to provide 1st order bias comp is overkill - and in Schiit's case they don't seem to have cracked it.
Yeah and higher order compensation should have even longer time constants, where an algorithmic/lut system might be the easiest way forward rather than clever circuits. Then the microprocessor can run an lcd (because glowy lights are cool) in addition to some clever power-up and SOA/protection monitoring (fan control would be nice, too). Oh, hey! We've got some smart people working on something like that here at diyaudio. :D
But none of that would materially show up in sweeps on an AP...
Joined 2014
Agreed. But because you don't need PSU rails as high as you do for a 150W/8 amp, you can use just two pairs of output devices per channel, now make those two pairs NJW 3281/1308, which are rated for 200W dissipation and watch them drive just about anything with PSU at +/-35V, quite enough for 50/8 .
Oddly enough that is something on the list. I was given a couple of 28-0-28 500VA transformers and was thinking of hooking that to one of Ostrippers designs for something with sensible power and excessive current.
I just fail to understand the need for a microprocessor-based bias control, save for novelty.
I'll give you a good reason: a SoC with integrated A/D and D/A floating between the output stage gates, reading the Re voltage, calculate the bias current, implement a nonlinear square law control loop to the output stage bias voltage. Net result: a non-switching output stage that pretty much leaves the crossover distortions history (and also the dreaded gm doubling region for bipolars). The idea is to keep the non-switching condition on the fly, at HF or any transient conditions (not only at DC and LF as many simple "non-switching" output stage topologies do).
Not a big deal to implement with a $5 SoC and a little software, some decent CPU and signal acquisition/processing speeds are required (trivial today), what I find very difficult is to determine the stability of the nonlinear control loop and it's interaction with other local and global feedback loops.
So, 40-0-40DC, OMG !! Just a 3 pair sanken OPS will run 2 paralleled 4R subs
with that low voltage. You can literally short the output stage with that 16A DC SOA at 40V.
The new 5 pair Sanken will burn toaster wire <1R@50V.
j2xgwDMBDSsnVA69OtCogRQzID4UOTOFEwAHkGJSmhPzgRIAFU7lagXmBJGuXwEwEMPlz8AaBEagAjDrBQAkcUj5iCtQwK0FSzhciBsQADs=
You have no idea ..... Display's , I2C datalogging , and even mobile control
is being "hatched" now. I'm "old school" , and am just concerned with
reliable DC/thermal/current/inrush with scriptable parameters.
PS - I have fan control if I want it , just changing the script can port
a thermal "event" to the fan (instead of shutdown). At least on mine ... I never
overheated. :)
OS
Joined 2014
OS
Basically :). I know it is senseless to build something just because I have transformers to use up, but what the hell. N+1 is the correct number of amplifiers to own, where N is the current number :)
As long as the analog bias control is primary.
Then use the uPC to "fine tune" it. (What if the processor fails?).
To go full AB2 would need a fast uPC - https://www.arduino.cc/en/ArduinoCertified/IntelGalileo .
You said -
I've seen member vzaichenko's new non-switching EF3 - a (really)good THD reduction
at 20Khz as well as LF. Analog can achieve this quite easily.
I think the best hybrid is to keep analog as primary and use the uPC to
do "housekeeping" (thermal FB + remote adjustment/logging).
As you said, the effect of a digital control loop within the analog output
stage might be quite unpredictable.
OS
You said -
I seen member vzaichenko's new non-switching EF3 - a (really)good THD reduction
OS
You've seen nothing when it comes to new $5 SoC's, Arduino is a pre-school kids slow toy ;). Speed is the last concern.
I've not seen that EF3 non-switching you are mentioning, but I certainly doubt you can implement true non-switching (with a square law, that is, keep the collector/drain output devices currents product constant for all frequencies and output levels) without a nonlinear feedback loop, be it analog or in the digital domain. Which makes both as difficult to deal with. I recall Edmond Stuart did an analog implementation, based on the LT1166 Linear Technology IC topology, unfortunately impaired by such stability issues.
The question is if such a digital bias schema is really required. I am pretty confident it won't have a iota of audible impact over any decent designed switching or non switching bias, while the sighted review chimps will only be appalled by this digital intrusion. So no, it could be just another technical challenge of the "because I can" type.
That's (my link) a 400Mhz Intel atom arduino.
Edmund also did the AB2 with discrete's. Even combined EC ...
Auto Bias part II
I built them ..... still like the simplicity/stability of a fast EF3.
(below) is the NS-OPS.
http://www.diyaudio.com/forums/soli...e-old-ideas-1970s-ips-ops-14.html#post4648520
I agree that some of this is "because I can". I can't hear any error with a plain
ol' EF3.
NS (and my plain ol' output stage) both use them big Sanken's.
The "NS" does shave several PPM's off of the load testing , I'm sure this would
get the "review chimps" hard. It is a tradeoff between the PPM and a few hot
extra current sources (and more complexity).
OS
