2stageEF high performance class AB power amp / 200W8R / 400W4R
Joined 2011
Try the Sanken 2SC4883A/A1859A which can still be gotten from Digikey. My models cover quasi-saturation:
THX for the models! A little bit higher Cob and lower Vce but maybe a good (and expensive) future replacement for the discontinued 2SC4793/2SA1837.
Due to the lower Vce maybe only usable for SA2015.
Funny: on the Digikey shop there is no information about discontinuation of 2SC4793 - only for the PNP part 2SA1837 with a watermark in the datasheet ...
Have Fun, Toni
Joined 2011
I was warned away from Unisonic transistors when they were being sold at Profusion by homemodder who said they were slow and inferior. This was for the D669/B649 pair but I imagine it applies to many of the others.
But, it would be nice to see some actual comparisons.
Thanks for info/warning. I've ordered 10 pieces
"2SC4793LB-TF3T, 2SA1837LB-TF3T" each from profusion for testing.
BR, Toni
Joined 2011
Ian Hegglun's cube-law amp uses 470R gate stoppers for the 20X20.
The amount needed probably depends a lot on what is driving the FETs, so you might be fine with more or less.
IMHO: a rather high value. I would have expected lower values due to lower fT compared to vertical mosfets but:
  • AN1850/LME49830/snaa058a.pdf recommends 22R for 2SK1530, 10R for 2SJ201. (Fig.3, page 3)
  • Bob Cordell uses 470R with 2SK1056/2SJ160 (laterals) (DAPA, fig. 11.1/p.216)
  • Bob Cordell uses e.g. 100R for verticals 2SK1530, 2SJ201 (DAPA, fig. 11.17, p.242). He also recommends to add a gate/drain zobel (e.g. 100R + 47pF) instead of reducing the speed of the mosfets
and an interesting application note for laterals from semelab:
http://products.semelab-tt.com/pdf/ApplicationNoteAlfet.pdf
p.11: "Gate Resistor Recommendations": 150R up to 470R.
Maybe a combination of a lower gate resistors and "cordell" gate zobels is the best way?
BR, Toni
Have Fun, Toni
Those models have been updated with correct Vaf values. The test didn't have very good resolution at high Vaf, so they could be a bit higher than that. In the past I may have sent you previous models with incorrect Vaf.
Joined 2011
Sorry - it was not my intention to criticize your bjt models. I meant the difference between the datasheets ... ;)
I will check my "keantoken_bjt_models_standard.lib" and add the new models. Thank you again for your excellent work providing us updated and new spice models! :)
Br, Toni
I do encourage you to find out on the bench what are acceptable gate stopper values, because often it's not the FET itself that becomes unstable, but the amplifier driving it. The stoppers can often be lowered quite a bit with good layout and optimized driving circuitry, or with a well-placed RC snubber.
I updated the Cjc of the P Sanken driver. The new models are in my latest model library, attached. There are several improvements:
Code:
* Version 9:
* 2SC4883A/A1859A: 	Updated Vaf and Cjc with measured values.
* 2SC5171/A1930:	Updated with quasi-saturation.
* 2SC3423/A1360:	Updated with more reasonable Vaf values, but need measurement.
* BC3x7-40:		Updated with measured Vaf values.
* KSC1845E:		Updated with measured Vaf values and quasi-saturation.
* KSA992F:		Updated with quasi-saturation.
* BC5x0C:		Updated with measured Vaf values for different factories.
* MPSA18/MMBT6429	New model with measured Vaf for a Fairchild MPSA18 and Rb according to the OnSemi datasheet.
  • kean9.bjt.txt
Joined 2011
Will do so. The annotation note of semelab presents a formula to pre-calculate such a resistor. The rest is practical work. I own a 150MHz scope so I should be able to check the oscillation sensitivity...
Many thanks - just downloaded!
BTW: the BC560 models still have hFe(BF?) of 900 which I have never seen. Most of my 2k Onsemi BC560CG are in the 600 range and most of my newest 2k Fairchild BC560CTA are in the 450 range.
nice buid astx
Thx!
Have fun, Toni
Do the BC560 show too high Hfe in simulation? Sometimes Bf can be higher than the actual beta of the transistor, in order to model an upward slope at low currents better.
Those models are based on Cordell's models, which may have been made for atypical devices.
Joined 2011
Those models are based on Cordell's models, which were made for atypical devices it seems.
Hmmm ... OK ... overflow ... sorry ... lack of knowledge here on this side ... thought spice parameter BF = hFe
:):crazy:
Yes
And yes, they don't come out quite as high as Bf would indicate, but still far lower base current is predicted compared to the 550/560C that I use.
Joined 2011
SA2013, SA2014, SA2015 housekeeping circuits
I've been asked several times mostly via PM to provide more information about the housekeeping circuits which I've developed and used in most of my current amplifier projects. If there's enough positive response here, I will think about providing gerbers and maybe firmware for programming the pic16f690 and the newer replacement pic16f1829...
Have fun, Toni
Joined 2011
