In H3 manual is not clair what pin is LRCK and what is BCK...
How I read it is that the one with 'SYNC' in the name is LRCK (WS). So I agree with your diagram in post5. PA18 looks to be WS/LRCK.
Yes, i tought too SYNC mean the Left\right clock.
maybe the problem is software
looking here i saw
i2s configuration
[i2s_para]
i2s_used: 0 to disable; 1 to enable
i2s_channel: channel control; 1 for one, 2 for two channels
i2s_mclk: master clock signal GPIO configuration
i2s_bclk: bit clock signal GPIO configuration
i2s_lrclk: word clock (left/right) signal GPIO configuration
i2s_dout0: digital out 0 GPIO configuration
i2s_dout1: (optional) digital out 1 GPIO configuration
i2s_dout2: (optional) digital out 2 GPIO configuration
i2s_dout3: (optional) digital out 3 GPIO configuration
i2s_din: multiplexed in signal GPIO configuration
Configuration example:
then I think in script.bin should be
(then not
i2s configuration
[i2s_para]
Code:
[i2s_para]
i2s_used = 1
i2s_channel = 2
i2s_mclk = port:PB05<2><1><default><default>
i2s_bclk = port:PB06<2><1><default><default>
i2s_lrclk = port:PB07<2><1><default><default>
i2s_dout0 = port:PB08<2><1><default><default>
Code:
i2s_used = 1
i2s_channel = 2
[COLOR="Red"]i2s_lrclk[/COLOR] = port:PA18<2><1><default><default>
i2s_bclk = port:PA19<2><1><default><default>
i2s_dout0 = port:PA20<2><1><default><default>
i2s_din = port:PA21<2><1><default><default>
(then not
Code:
i2s_mclk = port:PA18<2><1><default><default>
@skyunlimited, i didn't see the other setups, but i looking only [pcm0]:
i changed
daudio_used = 1 (before was 0)
i2s_lrclk = portA18<2><1><default><default> (before was i2s_mclk = portA18<2><1><default><default>)
Code:
[target]
boot_clock = 1536
storage_type = -1
[key_detect_en]
keyen_flag = 0
[fel_key]
fel_key_max = 7
fel_key_min = 2
[card_boot]
logical_start = 40960
sprite_work_delay = 500
sprite_err_delay = 200
sprite_gpio0 = port:PA15<1><default><default><default>
next_work = 3
[box_start_os]
used = 1
start_type = 1
irkey_used = 1
pmukey_used = 1
pmukey_num = 3
led_power = 0
led_state = 0
[boot_init_gpio]
used = 1
gpio0 = port:PA15<1><default><default><1>
gpio1 = port:PG11<1><default><default><1>
[recovery_para]
used = 1
mode = 2
recovery_key = port:PL04<0><default><default><default>
[pm_para]
standby_mode = 1
[card0_boot_para]
card_ctrl = 0
card_high_speed = 1
card_line = 4
sdc_d1 = port:PF00<2><1><2><default>
sdc_d0 = port:PF01<2><1><2><default>
sdc_clk = port:PF02<2><1><2><default>
sdc_cmd = port:PF03<2><1><2><default>
sdc_d3 = port:PF04<2><1><2><default>
sdc_d2 = port:PF05<2><1><2><default>
[card2_boot_para]
card_ctrl = 2
card_high_speed = 1
card_line = 8
sdc_cmd = port:PC06<3><1><2><default>
sdc_clk = port:PC05<3><1><2><default>
sdc_d0 = port:PC08<3><1><2><default>
sdc_d1 = port:PC09<3><1><2><default>
sdc_d2 = port:PC10<3><1><2><default>
sdc_d3 = port:PC11<3><1><2><default>
sdc_d4 = port:PC12<3><1><2><default>
sdc_d5 = port:PC13<3><1><2><default>
sdc_d6 = port:PC14<3><1><2><default>
sdc_d7 = port:PC15<3><1><2><default>
sdc_2xmode = 1
sdc_ddrmode = 1
[twi_para]
twi_port = 0
twi_scl = port:PA11<2><default><default><default>
twi_sda = port:PA12<2><default><default><default>
[uart_para]
uart_debug_port = 0
uart_debug_tx = port:PA04<2><1><default><default>
uart_debug_rx = port:PA05<2><1><default><default>
[force_uart_para]
force_uart_port = 0
force_uart_tx = port:PF02<3><1><default><default>
force_uart_rx = port:PF04<3><1><default><default>
[jtag_para]
jtag_enable = 0
jtag_ms = port:PA00<3><default><default><default>
jtag_ck = port:PA01<3><default><default><default>
jtag_do = port:PA02<3><default><default><default>
jtag_di = port:PA03<3><default><default><default>
[clock]
pll_video = 297
pll_ve = 402
pll_periph0 = 600
pll_gpu = 576
pll_periph1 = 600
pll_de = 864
[dram_para]
dram_clk = 672
dram_type = 3
dram_zq = 0x3b3bfb
dram_odt_en = 1
dram_para1 = 283377664
dram_para2 = 0
dram_mr0 = 6208
dram_mr1 = 64
dram_mr2 = 24
dram_mr3 = 2
dram_tpr0 = 0x48a192
dram_tpr1 = 0x1c2418d
dram_tpr2 = 0x76051
dram_tpr3 = 0x0
dram_tpr4 = 0x0
dram_tpr5 = 0x0
dram_tpr6 = 0x64
dram_tpr7 = 0x0
dram_tpr8 = 0x0
dram_tpr9 = 0x0
dram_tpr10 = 0x0
dram_tpr11 = 0x6aaa0000
dram_tpr12 = 0x7979
dram_tpr13 = 0x800800
[wakeup_src_para]
cpu_en = 0
cpu_freq = 48
pll_ratio = 273
dram_selfresh_en = 1
dram_freq = 36
wakeup_src0 =
wakeup_src_wl = port:PG10<4><default><default><0>
[twi0]
twi_used = 1
[twi1]
twi_used = 1
twi_scl = port:PA18<3><default><default><default>
twi_sda = port:PA19<3><default><default><default>
[twi2]
twi_used = 0
twi_scl = port:PE12<3><default><default><default>
twi_sda = port:PE13<3><default><default><default>
[uart0]
uart_used = 1
uart_port = 0
uart_type = 2
uart_tx = port:PA04<2><1><default><default>
uart_rx = port:PA05<2><1><default><default>
[uart1]
uart_used = 0
uart_port = 1
uart_type = 2
uart_tx = port:PG06<2><1><default><default>
uart_rx = port:PG07<2><1><default><default>
uart_rts = port:PG08<2><1><default><default>
uart_cts = port:PG09<2><1><default><default>
[uart2]
uart_used = 1
uart_port = 2
uart_type = 4
uart_tx = port:PA00<2><1><default><default>
uart_rx = port:PA01<2><1><default><default>
uart_rts = port:PA02<2><1><default><default>
uart_cts = port:PA03<2><1><default><default>
[uart3]
uart_used = 1
uart_port = 3
uart_type = 2
uart_tx = port:PA13<3><1><default><default>
uart_rx = port:PA14<3><1><default><default>
uart_rts = port:PA15<3><1><default><default>
uart_cts = port:PA16<3><1><default><default>
[spi0]
spi_used = 1
spi_cs_bitmap = 1
spi_mosi = port:PC00<3><default><default><default>
spi_miso = port:PC01<3><default><default><default>
spi_sclk = port:PC02<3><default><default><default>
spi_cs0 = port:PC03<3><1><default><default>
[spi1]
spi_used = 0
spi_cs_bitmap = 1
spi_cs0 = port:PA13<2><1><default><default>
spi_sclk = port:PA14<2><default><default><default>
spi_mosi = port:PA15<2><default><default><default>
spi_miso = port:PA16<2><default><default><default>
[spi_devices]
spi_dev_num = 1
[spi_board0]
modalias = "spidev"
max_speed_hz = 33000000
bus_num = 0
chip_select = 0
mode = 0
full_duplex = 1
manual_cs = 0
[gpio_para]
gpio_used = 1
gpio_num = 19
gpio_pin_1 = port:PL10<1><default><default><0>
gpio_pin_2 = port:PA15<1><default><default><1>
gpio_pin_3 = port:PA06<1><default><default><0>
gpio_pin_4 = port:PA13<1><default><default><0>
gpio_pin_5 = port:PA14<1><default><default><0>
gpio_pin_6 = port:PD14<1><default><default><0>
gpio_pin_7 = port:PA03<1><default><default><0>
gpio_pin_8 = port:PC04<1><default><default><0>
gpio_pin_9 = port:PC07<1><default><default><0>
gpio_pin_10 = port:PC03<1><default><default><0>
gpio_pin_11 = port:PA21<1><default><default><0>
gpio_pin_12 = port:PA07<1><default><default><0>
gpio_pin_13 = port:PA08<1><default><default><0>
gpio_pin_14 = port:PG08<1><default><default><0>
gpio_pin_15 = port:PA09<1><default><default><0>
gpio_pin_16 = port:PA10<1><default><default><0>
gpio_pin_17 = port:PG09<1><default><default><0>
gpio_pin_18 = port:PG06<1><default><default><0>
gpio_pin_19 = port:PG07<1><default><default><0>
[led_assign]
normal_led = "gpio_pin_2"
standby_led = "gpio_pin_1"
[ths_para]
ths_used = 1
ths_trip1_count = 5
ths_trip1_0 = 75
ths_trip1_1 = 85
ths_trip1_2 = 90
ths_trip1_3 = 100
ths_trip1_4 = 105
ths_trip1_5 = 0
ths_trip1_6 = 0
ths_trip1_7 = 0
ths_trip1_0_min = 0
ths_trip1_0_max = 1
ths_trip1_1_min = 1
ths_trip1_1_max = 2
ths_trip1_2_min = 2
ths_trip1_2_max = 3
ths_trip1_3_min = 3
ths_trip1_3_max = 4
ths_trip1_4_min = 4
ths_trip1_4_max = 4
ths_trip1_5_min = 0
ths_trip1_5_max = 0
ths_trip1_6_min = 0
ths_trip1_6_max = 0
ths_trip2_count = 1
ths_trip2_0 = 105
[cooler_table]
cooler_count = 5
cooler0 = "1536000 4 4294967295 0"
cooler1 = "1200000 4 4294967295 0"
cooler2 = "1008000 4 4294967295 0"
cooler3 = "816000 3 4294967295 0"
cooler4 = "504000 1 4294967295 0"
[nand0_para]
nand_support_2ch = 0
nand0_used = 0
nand0_we = port:PC00<2><default><default><default>
nand0_ale = port:PC01<2><default><default><default>
nand0_cle = port:PC02<2><default><default><default>
nand0_ce1 = port:PC03<2><default><default><default>
nand0_ce0 = port:PC04<2><default><default><default>
nand0_nre = port:PC05<2><default><default><default>
nand0_rb0 = port:PC06<2><default><default><default>
nand0_rb1 = port:PC07<2><default><default><default>
nand0_d0 = port:PC08<2><default><default><default>
nand0_d1 = port:PC09<2><default><default><default>
nand0_d2 = port:PC10<2><default><default><default>
nand0_d3 = port:PC11<2><default><default><default>
nand0_d4 = port:PC12<2><default><default><default>
nand0_d5 = port:PC13<2><default><default><default>
nand0_d6 = port:PC14<2><default><default><default>
nand0_d7 = port:PC15<2><default><default><default>
nand0_ndqs = port:PC16<2><default><default><default>
[boot_disp]
advert_disp = 0
auto_hpd = 1
output_type = 4
hdmi_channel = 0
hdmi_mode = 4
cvbs_channel = 1
cvbs_mode = 11
output_full = 1
hdmi_mode_check = 1
[disp_init]
disp_init_enable = 1
disp_mode = 0
screen0_output_type = 3
screen0_output_mode = 5
screen1_output_type = 3
screen1_output_mode = 5
fb0_format = 0
fb0_width = 0
fb0_height = 0
fb1_format = 0
fb1_width = 0
fb1_height = 0
fb0_framebuffer_num = 3
sunxi_fb_mem_reserve = 32
[hdmi_para]
hdmi_used = 1
hdmi_power = "vcc-hdmi-18"
[tv_para]
tv_used = 1
tv_dac_used = 1
tv_dac_src0 = 0
[pwm0_para]
pwm_used = 0
pwm_positive = port:PA05<3><0><default><default>
[gmac0]
gmac_used = 2
gmac_power1 =
[csi0]
vip_used = 1
vip_mode = 0
vip_dev_qty = 1
vip_define_sensor_list = 0
vip_csi_pck = port:PE00<2><default><default><default>
vip_csi_mck = port:PE01<2><default><default><default>
vip_csi_hsync = port:PE02<2><default><default><default>
vip_csi_vsync = port:PE03<2><default><default><default>
vip_csi_d0 = port:PE04<2><default><default><default>
vip_csi_d1 = port:PE05<2><default><default><default>
vip_csi_d2 = port:PE06<2><default><default><default>
vip_csi_d3 = port:PE07<2><default><default><default>
vip_csi_d4 = port:PE08<2><default><default><default>
vip_csi_d5 = port:PE09<2><default><default><default>
vip_csi_d6 = port:PE10<2><default><default><default>
vip_csi_d7 = port:PE11<2><default><default><default>
vip_csi_sck = port:PE12<2><default><default><default>
vip_csi_sda = port:PE13<2><default><default><default>
vip_dev0_mname = "gc2035"
vip_dev0_pos = "front"
vip_dev0_lane = 1
vip_dev0_twi_id = 2
vip_dev0_twi_addr = 120
vip_dev0_isp_used = 0
vip_dev0_fmt = 0
vip_dev0_stby_mode = 0
vip_dev0_vflip = 1
vip_dev0_hflip = 1
vip_dev0_iovdd = ""
vip_dev0_iovdd_vol = 2800000
vip_dev0_avdd = ""
vip_dev0_avdd_vol = 2800000
vip_dev0_dvdd = ""
vip_dev0_dvdd_vol = 1800000
vip_dev0_afvdd = ""
vip_dev0_afvdd_vol = 2800000
vip_dev0_power_en = port:PA17<1><default><default><1>
vip_dev0_reset = port:PE14<1><default><default><1>
vip_dev0_pwdn = port:PE15<1><default><default><0>
vip_dev0_flash_en =
vip_dev0_flash_mode =
vip_dev0_af_pwdn =
vip_dev0_act_used = 0
vip_dev0_act_name = "ad5820_act"
vip_dev0_act_slave = 24
vip_dev1_mname = ""
vip_dev1_pos = "rear"
vip_dev1_lane = 1
vip_dev1_twi_id = 0
vip_dev1_twi_addr =
vip_dev1_isp_used = 0
vip_dev1_fmt = 1
vip_dev1_stby_mode = 0
vip_dev1_vflip = 0
vip_dev1_hflip = 0
vip_dev1_iovdd = ""
vip_dev1_iovdd_vol = 2800000
vip_dev1_avdd = ""
vip_dev1_avdd_vol = 2800000
vip_dev1_dvdd = ""
vip_dev1_dvdd_vol = 1500000
vip_dev1_afvdd = ""
vip_dev1_afvdd_vol = 2800000
vip_dev1_power_en =
vip_dev1_reset =
vip_dev1_pwdn =
vip_dev1_flash_en =
vip_dev1_flash_mode =
vip_dev1_af_pwdn =
[tvout_para]
tvout_used =
tvout_channel_num =
tv_en =
[tvin_para]
tvin_used =
tvin_channel_num =
[di_para]
di_used = 1
[mmc0_para]
sdc_used = 1
sdc_detmode = 1
sdc_buswidth = 4
sdc_det = port:PF06<0><1><2><default>
sdc_use_wp = 0
sdc_wp =
sdc_isio = 0
sdc_regulator = "none"
sdc_power_supply = "none"
[mmc1_para]
sdc_used = 1
sdc_detmode = 4
sdc_buswidth = 4
sdc_clk = port:PG00<2><1><3><default>
sdc_cmd = port:PG01<2><1><3><default>
sdc_d0 = port:PG02<2><1><3><default>
sdc_d1 = port:PG03<2><1><3><default>
sdc_d2 = port:PG04<2><1><3><default>
sdc_d3 = port:PG05<2><1><3><default>
sdc_det =
sdc_use_wp = 0
sdc_wp =
sdc_isio = 1
sdc_2xmode = 1
sdc_ddrmode = 1
[mmc2_para]
sdc_used = 0
sdc_detmode = 3
sdc_buswidth = 8
emmc_rst = port:PC16<3><1><2><default>
sdc_det =
sdc_use_wp = 0
sdc_wp =
sdc_isio = 0
sdc_2xmode = 1
sdc_ddrmode = 1
[smc_para]
smc_used =
smc_rst = port:PA09<2><default><default><default>
smc_vppen = port:PA20<3><default><default><default>
smc_vppp = port:PA21<3><default><default><default>
smc_det = port:PA10<2><default><default><default>
smc_vccen = port:PA06<2><default><default><default>
smc_sck = port:PA07<2><default><default><default>
smc_sda = port:PA08<2><default><default><default>
[usbc0]
usb_used = 1
usb_port_type = 1
usb_detect_type = 0
usb_id_gpio = port:PG12<0><1><default><default>
usb_det_vbus_gpio = port:PG12<0><1><default><default>
usb_drv_vbus_gpio = port:PL02<1><0><default><0>
usb_host_init_state = 1
usb_restrict_gpio =
usb_restric_flag = 0
usb_restric_voltage = 3550000
usb_restric_capacity = 5
usb_regulator_io = "nocare"
usb_regulator_vol = 0
usb_not_suspend = 0
[usbc1]
usb_used = 1
usb_drv_vbus_gpio =
usb_restrict_gpio =
usb_not_suspend = 0
[usbc2]
usb_used = 1
usb_drv_vbus_gpio =
usb_restrict_gpio =
usb_not_suspend = 0
[usbc3]
usb_used = 1
usb_drv_vbus_gpio =
usb_restrict_gpio =
usb_not_suspend = 0
[usb_feature]
vendor_id = 6353
mass_storage_id = 1
adb_id = 2
manufacturer_name = "USB Developer"
product_name = "Android"
serial_number = "20080411"
[msc_feature]
vendor_name = "USB 2.0"
product_name = "USB Flash Driver"
release = 100
luns = 3
[serial_feature]
serial_unique = 0
[module_para]
module_num = 7
module_power0 = "vcc-wifi-33"
module_power0_vol = 0
module_power1 =
module_power1_vol =
module_power2 =
module_power2_vol =
module_power3 =
module_power3_vol =
chip_en =
lpo_use_apclk =
[wifi_para]
wifi_used = 0
wifi_sdc_id = 1
wifi_usbc_id = 5
wifi_usbc_type = 1
wl_reg_on = port:PL07<1><default><default><0>
wl_host_wake = port:PG10<0><default><default><0>
wl_host_wake_invert = 0
[bt_para]
bt_used = 0
bt_uart_id = 1
bt_rst_n =
bt_wake =
bt_host_wake =
bt_host_wake_invert = 0
[pcm0]
daudio_used = 1
daudio_master = 4
daudio_select = 1
audio_format = 1
signal_inversion = 1
mclk_fs = 128
sample_resolution = 16
slot_width_select = 32
pcm_lrck_period = 32
pcm_lrckr_period = 1
msb_lsb_first = 0
sign_extend = 0
slot_index = 0
slot_width = 32
frame_width = 0
tx_data_mode = 0
rx_data_mode = 0
i2s_lrclk = port:PA18<2><1><default><default>
[pcm1]
daudio_used = 0
daudio_master = 4
daudio_select = 1
audio_format = 1
mclk_fs = 128
msb_lsb_first = 0
sign_extend = 0
slot_index = 0
slot_width = 32
frame_width = 0
tx_data_mode = 0
rx_data_mode = 0
i2s_mclk = port:PG10<2><1><default><default>
i2s_bclk = port:PG11<2><1><default><default>
i2s_dout0 = port:PG12<2><1><default><default>
i2s_din = port:PG13<2><1><default><default>
[audio0]
audio_used = 1
lineout_vol = 31
cap_vol = 5
audio_hp_ldo = "none"
adcagc_used = 0
adcdrc_used = 0
dacdrc_used = 0
adchpf_used = 0
dachpf_used = 0
audio_pa_ctrl = port:PA16<1><default><default><0>
[spdif0]
spdif_used = 0
spdif_dout = port:PA17<2><1><default><default>
[audiohub]
hub_used = 0
codec_used = 1
spdif_used = 1
hdmi_used = 1
[s_cir0]
ir_used = 1
ir_rx = port:PL11<2><1><default><default>
ir_power_key_code0 = 87
ir_addr_code0 = 40704
ir_power_key_code1 = 26
ir_addr_code1 = 64260
ir_power_key_code2 = 20
ir_addr_code2 = 32640
ir_power_key_code3 = 21
ir_addr_code3 = 32640
ir_power_key_code4 = 11
ir_addr_code4 = 63240
ir_power_key_code5 = 3
ir_addr_code5 = 239
ir_power_key_code6 = 159
ir_addr_code6 = 19635
ir_power_key_code7 = 10
ir_addr_code7 = 30536
ir_power_key_code8 = 69
ir_addr_code8 = 48386
ir_power_key_code9 = 77
ir_addr_code9 = 56865
ir_power_key_code10 = 24
ir_addr_code10 = 65025
ir_power_key_code11 = 87
ir_addr_code11 = 65280
ir_power_key_code12 = 77
ir_addr_code12 = 65344
[cir]
ir_used = 1
ir_tx = port:PH07<2><default><default><default>
[dvfs_table]
pmuic_type = 2
pmu_gpio0 = port:PL06<1><1><2><1>
pmu_level0 = 11300
pmu_level1 = 576
extremity_freq = 1536000000
max_freq = 1536000000
min_freq = 480000000
LV_count = 8
LV1_freq = 1536000000
LV1_volt = 1500
LV2_freq = 1200000000
LV2_volt = 1300
LV3_freq = 0
LV3_volt = 1100
LV4_freq = 0
LV4_volt = 1100
LV5_freq = 0
LV5_volt = 1100
LV6_freq = 0
LV6_volt = 1100
LV7_freq = 0
LV7_volt = 1100
LV8_freq = 0
LV8_volt = 1100
[gpu_dvfs_table]
G_LV_count = 3
G_LV0_freq = 312000000
G_LV0_volt = 1200000
G_LV1_freq = 384000000
G_LV1_volt = 1200000
G_LV2_freq = 456000000
G_LV2_volt = 1200000
[Vdevice]
Vdevice_used = 0
Vdevice_0 = port:PH10<5><1><2><default>
Vdevice_1 = port:PH11<5><1><2><default>
[s_uart0]
s_uart_used = 0
s_uart_tx = port:PL02<2><default><default><default>
s_uart_rx = port:PL03<2><default><default><default>
[s_rsb0]
s_rsb_used = 1
s_rsb_sck = port:PL00<2><1><2><default>
s_rsb_sda = port:PL01<2><1><2><default>
[s_jtag0]
s_jtag_used = 0
s_jtag_tms = port:PL04<2><1><2><default>
s_jtag_tck = port:PL05<2><1><2><default>
s_jtag_tdo = port:PL06<2><1><2><default>
s_jtag_tdi = port:PL07<2><1><2><default>
[s_powchk]
s_powchk_used = -2147483648
s_power_reg = 0
s_system_power = 50
[sim0]
scr_used = 0
scr_vccen = port:PA06<2><default><default><default>
scr_slk = port:PA07<2><default><default><default>
scr_sda = port:PA08<2><default><default><default>
scr_rst = port:PA09<2><default><default><default>
scr_det = port:PA10<2><default><default><default>
[ts0]
tsc_used = 0
tsc_clk = port:PE00<3><default><default><default>
tsc_err = port:PE01<3><default><default><default>
tsc_sync = port:PE02<3><default><default><default>
tsc_dvld = port:PE03<3><default><default><default>
tsc_d0 = port:PE04<3><default><default><default>
tsc_d1 = port:PE05<3><default><default><default>
tsc_d2 = port:PE06<3><default><default><default>
tsc_d3 = port:PE07<3><default><default><default>
tsc_d4 = port:PE08<3><default><default><default>
tsc_d5 = port:PE09<3><default><default><default>
tsc_d6 = port:PE10<3><default><default><default>
tsc_d7 = port:PE11<3><default><default><default>
[gpio_power_key]
key_used = 1
key_io = port:PL03<6><default><default><0>
[key_para]
key_used = 0
key_cnt = 5
key1_vol = 222
key2_vol = 444
key3_vol = 666
key4_vol = 857
key5_vol = 2000
[d7s_para]
d7s_used = 0
din_gpio = port:PD00<1><default><default><1>
clk_gpio = port:PD01<1><default><default><1>
stb_gpio = port:PD02<1><default><default><1>
[mali_para]
mali_used = 1
mali_clkdiv = 1
mali_extreme_freq = 600
mali_extreme_vol = 1400
[w1_para]
w1_used = 1
gpio = 20
i changed
Unless there are no I2S Modules, it is not possible to use the Pins even if they are connected. I found this thread concerning to Sunxi i2s modules, for the H3 it must be quite the same https://groups.google.com/forum/#!topic/linux-sunxi/t44VY2-cOMo[1-25]
Only linux distrbutions with i2s enabled kernels and with the DAC chipset driver loaded can work for any i2s board and I think at the moment only this kind of linux distributions should be tested on OPI for test i2s boards.
Some Volumio or maybe latest Raspbian well adapted for OPI can be good targets for try, but no any other kind of linux distributions.
Do you know if there are any distributions with Kernelmodules?
My Internet Connection is volume-based so i can not download all...
Hi Skyunlimited
You can try Volumio for OPI. I dont know if is yet fully functional but for test purposes maybe can try only if i2s dac work.
Volumio 1.55 for OrangePi available for test - Other - OrangePi - Powered by Discuz!
You can download lastest Raspbian for OPI that teorically have i2s enabled but and although perhaps dont have your dac especific driver (i dont know that) maybe you can try if your dac is properlly detected trougth i2s device.
http://www.orangepi.org/downloaded/download.html
Hi Skyunlimited
Volumio and Raspbian have implemented drivers i2s in its version of Raspberry Pi.
These images are ported to run on Orange pi, but that does not mean that the kernel is ready to operate the bus I2s.
Hey guys,
I am also considering building a nice audio player with Orange Pi + DAC... And because there is not much about it on internet, I found your thread staight away
Unfortunately I do not own any Orange Pi yet and it'll take a few weeks to get one, so I cannot verify if I am not posting any nonsense, but isn't this blog post:
koalo's blog: I²S Audio Support for Raspberry Pi
exactly what you are trying to achieve? It seems to me that it could be used in some way also for Orange Pi...
Hope it helps!
Regards.
Hope it helps!
Regards.
Hi to allDo you know if there are any distributions with Kernelmodules?
i2s enabled kernels
[ 4.327484] ALSA device list:
[ 4.334020] #0: audiocodec
[ 4.340439] #1: snddaudio
[ 4.346658] #2: sndhdmi
root@OrangePI:~# cat /proc/asound/cards
0 [audiocodec ]: audiocodec - audiocodec
audiocodec
1 [snddaudio ]: snddaudio - snddaudio
snddaudio
2 [sndhdmi ]: sndhdmi - sndhdmi
sndhdmi
https://drive.google.com/open?id=0B3COWn8ZF1MBcXdnakZuTlhXdlE
only OrangePi PC password: orangepi
fs_resize
web interface Logitech Media Server orangepi:9000
I have downloaded the Image and the OPi Pc is booting.
Next I have tried to install the alsa-utils and got a lot of errors:
Did you try connecting a soundcard via i2s?
Code:
Use of uninitialized value $value in substitution (s///) at /usr/share/perl5/Debconf/Format/822.pm line 65, <__ANONIO__> line 29358.
Use of uninitialized value $value in substitution (s///) at /usr/share/perl5/Debconf/Format/822.pm line 65, <__ANONIO__> line 29360.
Use of uninitialized value $item in hash element at /usr/share/perl5/Debconf/DbDriver/File.pm line 85, <__ANONIO__> chunk 29361.
Selecting previously unselected package libsamplerate0:armhf.
dpkg: unrecoverable fatal error, aborting:
files list file for package 'manpages-dev' is missing final newline
E: Sub-process /usr/bin/dpkg returned an error code (2)
Wow! It works. Second try, I extracted the kernel from ua3nbw ,everthing that is in "boot" and the folders firmware and modules (to be found in lib) and copied them to the sd card with Jacers Img. Then I connected the card as shown in #21 and
gives me pink noise on both channels....
It would have been nice to have HDMI with all Channels and no downmix to 2 but anyway:
Thanks for this great work ua3nbw !
Code:
sudo speaker-test -D hw:1 -c 2
- PC Based
- i2s connection - Orange/Dac
