50-300Hz front horn
Hello all,
I plan to do a exponential horn to cover 50-300Hz region.
Please be so kind and answer some questions before i start making saw dust :)
My previous experience with horn is limited, i only completed a 220Hz tractrix horn. I like what i hear so i thought adding horn bellow would be great. It would result a 3way active system, crossed at 300 and 2.6k Hz.
The data you see in Hornresp is not final, only Fc 50Hz and mouth area is final. I will play more with parameters so that response is ripple-free. Driver used in this sim is B&C12MH32.
Questions:
1. Look at the Hornresp simulated response. Do you think it goes low enough not to need additional subwoofers?
2. Is there any restriction on how i will bend the exponential horn? I mean the radius on the curved axial line. I liked what i saw on inlowsound's site, that spiral horn. I need to make it spiral as it is 1.8m in length.
3. The mouth ratio between height and width. Is there a recommendation?
Feel free to dismiss my project, i need advice from experienced people.
Thank you!
I'm not very experienced but would guess bass response would sound reasonably solid and have good dynamics
here's a little hypex horn I had built simulated with its Community 111913 12" speaker vs your horn with the same speaker. My folded horn has an external bulk of about 198 liters. A subwoofer could help in my case.
GM
Joined 2003
Questions:
1. The XO point will be at -3 to -6 dB, so this is a ~60 Hz usable horn and no, it doesn't go low enough. For most recordings it requires a ~flat in room response down to ~42 Hz and of course down to 16 hz for them all.
2. Yes, you must bend the horn to allow its highest planned frequency to go around any bend unimpeded, so look to the early W.E. horns for inspiration same as John? apparently did.
3. The pioneers determined that up to a ~1.0:1.273 aspect ratio was acceptable.
GM
I've built many horns, and I understand your desire to try and cover off this range without a sub. Physics work against you, however as GM alludes to.
I've designed two smaller horns than the Inlow large model. You could consider having this CNC'd in ply, or use John's "traditional" method. Using B&C PE32 12-inch you'll meet your target.
Andrew.
Thanks Andrew,
I simulated a horn with this driver and it is very good indeed.
Flat line from 60 to 400hz at 110dB@1W.
Usually I listen at lower volumes. Do you think that the response will not be so flat when listening at let's say.. 85dB ?
My understanding is that the sensitivity rating 110dB@1w is completely separate to the overall smoothness. Playing at 85 should be same as 90.
I've just drawn up another horn today, while on holidays. Like Sato but for 6, 8, or 10 inch pro driver. Details to follow. Would be a CNC delight, but still exotic.
I never completed my bass horn.
Any info I have is secondhand and mostly based on "old school" empirical design methods, except for Hornresp.
And Hornresp sort of confirmed what "old school" had suggested.
Truncating a horn leads to ripple.
One can minimise ripple by minimising the truncation. Trying horn length >=60% of the full horn length for your cut-off frequency. I think the Tannoy Westminter Royale/HR is truncuated even lower.
Choose an expansion rate that suits a frequency BELOW your cut-off frequency. Some have suggested half an octave below.
You are using 1Pi space. You are required to acoustically couple the horn to TWO boundaries. Floor and side wall are probably the easiest to couple to. That has allowed you to cut mouth area to 25% without affecting response.
Look at cone excursion for frequencies below your cut-off. They are likely to be frighteningly large due to the truncated horn unloading at these lower frequencies. I think it is for this reason that GM and Atil are suggesting your horn is too small.
Have you looked at firing the horn into a corner?
That would require your other speaker to extend down to upper bass.
A two foot gap from the mouth edge to the boundary is not negligible.
If it is a near square mouth then all four edges should be acoustically coupled to the three boundaries for a 0.5Pi loading.
I can only see that being met by a mouth firing into the corner where the gaps to the corner boundaries meet the "folded" form of the extended horn, or by building the mouth into the corner, i.e. the horn box is outside the listening room.
It's the same for a speaker baffle that is not built into the boundary wall. If one mounts the speaker baffle flush with the boundary wall then baffle step response does not occur. Build the box inside the room and the baffle step has to be compensated for. Even when the box places the baffle just a foot in front of the boundary wall.
