Tube or solid state?
How much do you want to spend?
Bottlehead Crack is a good headphone amp, IMO and has good instructions.
You won't save much by buying a 'kit' vs a built version if you are looking at the cheaper solid state HP amps, and with the 'ready to use' amps you have some warranty protection.
Cruise over to head-fi and you will have reading for weeks...
i'm not entirely qualified to answer the kit or type but i will say that unless you can solder and have a semi decent iron then i would start by learning to solder first. saying that i use a £14 temp adjustable one i got off ebay and it does the job just dandy but i can also weld and braze.
i was told recently to build a cmoy amp as it would help me understand things a bit better. How to Build the CMoy Pocket Amplifier
or you can do this as you don't even need a circuit board DIY Enthusiast Discussion Thread - DIY AMPS, Custom Cables & More - Page 83 - www.hardwarezone.com.sg
http://runawaybrainz.blogspot.sg/2012/04/audio-crystal-cmoy-freeform-headphone.html
one you start there is no going back... its addictive lol
If breaking any rules im sorry.Do you see any problems for a newbie in making this it seems straight forward enough
http://pages.ebay.com/link/?nav=item.view&id=120686919384&alt=web
mick
mick
Looks like you should be able to assemble it ok. Get some 63/37 solder (eutectic) and a wet sponge for your iron.
It seems to say that some(?) of the parts are used, that may be why the price is low.
Thank you for quick reply.Why 63/37 solder
This one seems very good and not so many parts
ZEROZONE TU1-EMP V2 Tube headphone amplifier kit 2X 6922 + 1X 12AT7 L1511-19 | eBay
It's the best kind for good electronic solder joints. Don't use the 60/40 type.
mick
I've listened to one of those for years until it recently gave up.
I liked it very much.
For SQ I'd swap to Wima or similar filmcaps where possible ( the smaller caps lets say under 1uF),
I had a 2x15 1A toroidal transformer powering mine.
When it comes to solder, my favorite by far is the 60/38/2 (2% Copper).
mick
I've built several of those. They're quite good for the price but the overall sound quality is quite dependent on your choice of op-amp.
This folded cascode job? Why not.
http://www.diyaudio.com/forums/headphone-systems/221480-my-e5-class-hifi-headphone-amp.html
I don't really like the 75 ohm output impedance though (and who knows whether it's stable without that), unless you just happen to have headphones that appreciate this kind of value, plus I highly doubt you'd get anything even resembling original 2SK170s with a kit like this (there's like a gazillion fakes of these now-rare discontinued devices out there, none of them being remotely close in their characteristics, the only known substitute is the Linear Systems LSK170).
It will be a little bit more involved than a kit you buy ready to mount, but here's another one which I like the schematic of:
http://www.diyaudio.com/forums/pass-labs/271926-f5-headamp.html
More involved because you will have to have PCB made (unless you find someone on that thread with extra to sell), order components, etc...
- Headphone Systems
- Recommend a kit for newbie
