el84 se amp layout
not to sure which way to layout components on the board
any ideas size is 30x30 cm or 12x12 in imperial
trying to keep input away from power supply
wildmouse
thanks
Seems like the rh layout might be the one. I he opt are 90degrees to the power tx' , if I have problems with that I will rotate them 45 degrees and put covers on them
Hope to get the plate drilled today, and the bus bar grond wire in the next few days
thanks
wild mouse
Hello All ...
so possible build to 25 x 30 cm ...
look the 6V6 GT SE UL ...
Mine is 20cm by 30cm and everything fits in easily.
I just finished wiring up the output stages and the power supply. After checking the heaters were OK and the the HT and then the cathode volts were OK I connected a speaker. When I turned on there is some mains hum right away, before the valves heat up. When the valves start to operate there is some buzz, most likely from the unconnected grid of the EL84.
The hum immediately at switch on concerns me. I have the power transformer at right angles to the output transformers. Initially I was connect to the ouptu transformer nearest the power transformer. Then I connected the speaker to the output transformer furthest away from the power transformer and the initial hum is no longer there. This convinces me it is induced from the power transformer.
Cheers
Ian
el 84 SE amp finished
Finally finished ,been playing for 1 hour now.
power tranny a little hot, only rated at 69ma.
the build is based on shannons budgie using hammond iron, 369jx and 125cse opt
I have a switch for petode or triode mode ,but triode mode is way loud enough
n ot much bass, but bueatiful midrange
no noise at all
im happy
glen
