Hypex Ncore
Yes, the platform is dedicated for audio, with a tweaked down OS installation. Only extent of internet access is for streaming audio.
Yes for DIY folks, a PC based active loudspeaker is most flexible and capable.
For an OEM trying to make an active loudspeaker product, embedded DSP probably makes more sense
Unless you use a rock solid realtime OS like Masscore. Then it's as rock solid as a DSP chip.
I wouldn't recommend running a commercial system off Windows or OSX.
You don't want to use the same PC you do your daily internet browsing on for this task. You install a clean OS, and dedicate it for DSP duties.
So what is "PC" about it then?
What you are talking about is a dedicated, embedded computer - just one based on a general-purpose architecture rather than a DSP processor.
Embedded chips also add noise, jitter, and are limited in resolution.
Can you explain why the type of processor makes a difference to noise and jitter? Do you have numbers to support that assumption? The fact that a dedicated DSP platform doesn't need to deal with the extremely high frequencies of video etc. actually helps make them quieter. The higher-end dedicated DSP processors work at 64-bit floating point - does an Intel-based PC offer higher precision than that?
Try finding a DSP chip that can preform DSP to a 1 bit Native DSD signal, without conversion to PCM.
Try finding anything at all, hardware or software, that can do DSP (beyond simple scaling) in 1-bit native DSD. There is a reason pretty much all DSP packages convert 1-bit DSD either to multi-bit "PCM-wide" (which is really PCM with noise shaping) or DXD (24-bit, 352.8/384 kHz PCM) and back.
Well the same hardware of a "PC" can do it. But yes it would be turned into a dedicated engine.
All you have to do is look at the noise and jitter specs of what's on the market for chip based DSP, to see what I'm talking about. None of these DSP boxes like DEQX have specs to match the best stand alone DAC's to my knowledge. And yes we finally have 64bit floating point processing in the new SHARC 589 chip. But still not much power compared to Intel CPU's.
HQplayer can apply DSP to DSD. It converts the DSD into Multibit DSD to apply the DSP. The same way DAC chips like Sabre do to control volume on a DSD signal.
I think its rather you being silly bashing a companies particular way of doing business. If you don't like or can't afford it, find an other product.that suits your needs and budget. Silly - no!
Fair enough - but the "silly" referred to licence managers that tie you down to a specific installation - and it has nothing to do with being able to afford it. What I don't want is being dependent on a depreciated, "sorry, not supported" environment - something all too familiar for users of Windows 98 or Vista.
And preferably without display controllers, hard disks etc.
I think we are mixing up two separate things. You can't compare a full DSP chain (feeding a built-in DAC, and possibly containing an ADC step) with just a stand-alone DAC. They don't perform the same function. Do you have comparisons of jitter and noise performance of a PC, running DSP operations, feeding a DAC, compared to a stand-alone DSP box?
True. It is a trade-off - do you want a small, low-power, low-noise dedicated box with enough power for "normal" DSP, or a very flexible, powerful, power-hungry and noisy general purpose computer. It all depends on your application.
Precisely. You either do (multiple) conversions/resamplings between 1-bit and multibit, or you do a conversion to PCM (DXD) and back, because you can't do DSP in 1-bit.
Are you all Christmas shopping?
Rev A buffer board arrived back with me, will not have chance to test till weekend, busy building customers amps.
It looks very neat and tidy, assume that is a LM4562 in the 8 pin socket.
Looking forward to hearing your views on the different op amps. Of course with the uprated Hypex regulators I suppose it could sound better even with the standard LM4562.
NCore NC400 DIY kit
So at Hypex we wanted to make DIY-ing a bit more accessible and we came up with this:
https://www.hypexshop.com/DetailServlet?detailID=7616
It is a complete kit with everything included: NC400, SMPS600, Hypex case, cables and connectors. Tell me what you think and feel free to contact us at sales@hypex.nl
Cheers!
