For the no longer available driver from Fane - go to
https://community.klipsch.com/uploads/monthly_10_2013/post-16064-13819274140084.jpg
I need a replacement with similar character.
The target frequency range for operate is between 250 and 3000 Hz.
Follow currently available and maybe appropriate transducers I have found for replace the FANE Studio 8M:
Fane Sovereign 8-225
http://www.fane-international.com/downloads/Fane Sovereign 8225 DS030513.pdf
Eminence Alpha 8A
http://www.eminence.com/pdf/Alpha_8A.pdf
Eighteensound 8M400
http://www.eighteensound.it/Portals/0/PDFs/8M400.PDF
Are there better alternatives?
Eminence Alpha 8A
Eighteensound 8M400
I have a pair factory sealed.
One was opened today to take photos.
I was a manufacturer in the 1980's -90's and used Fane speakers in production.
These were built in July 1992.
On eBay now:
Fane Studio 8M 8" Midrange Speakers 1 Pair | eBay
On eBay now:
FANE Crescendo 8MB
an successor with an excellent sonic quality is this FANE driver:
http://www.subaudio.org/download/fane/Fane_hp_crescendo_8MB.pdf
Unfortunately I don't find it on FANE's websites.
Is this transducer also obsolete in the meantime?
Blue Aran have a large range of Fane speakers.
https://www.bluearan.co.uk/
thank you. this driver seems to be close to the crescendo 8 BMBlue Aran have a large range of Fane speakers.
http://www.fane-international.com/downloads/Fane-SovereignPro-8225-DS240316.pdf
They are very good, best prices too.
I have bought about 20 speakers of them and never had a problem.
good advice - thank you therefore. Maybe I start a new two-way sattelite speaker project for home audio application with this low-mid driver and either with the SICA tweeterThey are very good, best prices too.
model "LP 90.28/ N92 TW" (Code Z009160) - go to
LP 90.28/ N92 TW
and
http://img08.shop-pro.jp/PA01036/661/product/23201999_o2.jpg
or the custom made "Glockenklang" tweeter
(for BassArt III, UnoRock, BlueSky and BlueSoul) - go to post #6 under
http://www.diyaudio.com/forums/mult...glockenklang-phenol-99db-based-rcf-tw116.html
and
https://www.glockenklang.de/en/news.htm
Ideal for single ended power amplifier with low power output like ZEN and "Power Follower" from Andrea Ciuffoli.
Maybe with an active crossover network without additional operational amplifiers like second PDF file in post #1 under
http://www.diyaudio.com/forums/pass...itional-op-amp-ultimate-sounding-phl1230.html
LuxAUDiO LAA-97 equipped with Fane Studio 8M - Schematic wanted
For performing some upgrades I want to have a service manual. Who know trhe manufacturer from this active loudspeaker with passive crossover ?
Blue Aran - Professional Sound and Lighting have loads of Fane drivers.
They are usually best on price too.
404 - File or directory not found.
Eminence Alpha 8A
Eighteensound 8M400
Seems like the eighteensound is more powerfull , and has more pressure level? Would this one be an upgrade for your cab?
What other parameters are important to check (more than the thiele small parameters are close to your speaker needs)?
- Replacement for Fane Studio 8M wanted
