diyAudio Member RIP
Joined 2005
cascoded source follower? :confused:
regards, Gerhard
Yes, bootstrapped cascode, BF862 and ~PN4391. Mostly eliminates the variable voltage across the BF862, and with it various distortions, while also lowering Vds to about 4V and reducing dissipation and signal-induced dissipation shifts. The current source loading of the source and light loading by the op amp input means 862 Cgs is also rendered of little effect.
It eats up common-mode range, but for phono is not a concern.
Borbely has done this sort of cascoding with 2SK170s and 2SK246 parts.
Please see the attached file, OPA1641 was measured.
With a 1k loading, how much of what you're seeing is OPS and how much of that is common mode error? It's also one of the lower bandwidth parts on that list (not by such a huge margin as to explain the 20x difference, however).
Edit to add: John Caldwell (BB/TI App engineer) has said that the 1642 moved to a different process to help with common mode issues. Forgot the thread. Not sure if your part is before/after that change (not sure if that'd affect this load condition, however).
(And thanks for that data!)
diyAudio Member RIP
Joined 2005
gerhard,
Here's a nice paper on thermal drift issues and 1/f noise with some measured data. MAT03's at .5 Hz or so corner. This is the first time I saw a theory vs. data on the 1/f^4 spectra due to thermals even though I have observed similar things over the years.
http://arxiv.org/pdf/physics/0503012.pdf
That's interesting. They didn't look very hard for lower-noise JFETs, and their Wilsonian mirror could be quieter (although its noise is largely nulled). But I like the discussion about the LF noise.
I was looking at the part for a budget MM phono pre application, and noted the 5.1nV/sq rt Hz noise density, the preceding part having been the OPA2134.
But I think I will allow a trifle higher parts count and use an AD797 or LME49990 preceded by a BF862 cascoded source follower and servo. The overall input voltage noise will still be acceptably small, although could be reduced by a more elaborate series feedback arrangement for the JFET. Things rapidly spiral into complexity, and I'd like frequency compensation to be simple for a change.
Keep in mind the intrinsic noise of the cartridge and input network. How much below that do you need to be for an uncorrelated noise source?
gerhard,
Yes, I have a similar design. The principle is around since Precision Monolitics times.
< https://picasaweb.google.com/lh/photo/AWKl7tzKFwX5wMVbdLFvrNMTjNZETYmyPJy0liipFm0?feat=directlink >
And somewhat cheaper:
< https://picasaweb.google.com/lh/photo/Bz6NkIibR7_yQyuKdwpPzNMTjNZETYmyPJy0liipFm0?feat=directlink >
Rubiola is a big shot in the time/frequency scene. His website is Enrico Rubiola home page.
Lots of interesting stuff. His book is excellent, also.
regards, Gerhard
ps: does anybody still make these nice plated-through boards with
ground, formerly Vero Powerplane boards?
Those from Roth are not plated-tru and are un-tinned.
diyAudio Member RIP
Joined 2005
Essentially no input termination noise using the cooled termination approach, so the overall noise will be dominated by thermal cartridge noise, which will be nice. I'd share the schematic, but this is for a client (and indirectly two of them in fact) and they would be upset.
diyAudio Member RIP
Joined 2005
If the JFETs had a lower output conductance it would help, so perhaps that is part of the process change.
PS: Mouser shows the LME49990 as at an imminent end of life. But TI doesn't mention this on the datasheet. Anyone know what is up?
From the data sheet, I suppose the 1/f frequency is 99.5 Hz or so :)
Not really interesting when you are into 1/f.
JFET manufacturers seem to abhor data sheets. Yes, that's all.
regards, Gerhard
diyAudio Member RIP
Joined 2005
regards, Gerhard
I seem to recall that Danyuk measured a rather lower corner for the BF862, but I would have to dig out the article he did to verify this. But you are right, specs on FETs are meager.
