One of the application of an LED is to bias a bipolar transistor, e.g. to make up a current source, using a emitter resistor to set the current.
For perfect bias stability, the LED and the BJT should have the same tempco.
If I am not wrong, the tempco of a PN junction is -2.2mV/K.
(Current Sources and Voltage References: A Design Reference for Electronics ..., Linden T. Harrison)
Opto-couplers tend to use GaAlAs LEDs at ~880nm. Their tempco is about -1.8mV/K.
The only LED I can find in literatures that has close to -2.2mV/K is GaN at 375nm.
We have done some simple experiments with a CCS made of BJT & 630nm as well as BJT & 375nm.
The latter was more stable over a temperature range of 30°C.
Wonder if anyone else has similar experience or even better solutions ?
Thanks in advance,
Patrick
Thanks in advance,
Patrick
https://books.google.co.th/books?id...2BAn2#v=onepage&q=diode painted black&f=false
Bob Peese section of his book....
The good old two transistor CCS does not have any problems with light interference. And if you run enough current through the main pass transistor it will even glow for you like an indicator
Ditto for a 4 transitor ccs, two PNP on top of two NPN, which adds quite a bit of dB of PSRR, but at the obvious costs of double the cheap silicon. The price difference works out to nothing in the overall scheme of things.
Purely academic, but what is the mechanism that makes a smaller LED noisier ?
Never had kids, eh?
se
It usually comes down to current density issues.
1, he says I'm giving him a headache.
Hehe. You need two so you can have a "smaller one."
se
Same thing than when you parallel two transistor VS one you win 3dB ?Purely academic, but what is the mechanism that makes a smaller LED noisier ?
(or you can think temperatures of the junction)
a "smaller one."
Lt. Steve, you still haven't deduced I'm not exactly smart ?
(a smaller one is a matter of wear, not wind)
Hehe. No, but I'm learning.
Ah, but it is the wind that carries the grains of sand that do the wearing, Grasshopper.
se
se
At last an area where I have real experience. I have many!
Hehe. Ironically, I have none. But I do have a little sister, so I do know of the mighty wind that can issue forth from "a smaller one."
"MOOOOOOOOOMMMM! STEVE PULLED MY HAIR AGAIN!!!"
se
Do other diode types offer benefit for biasing purpose.
Principles, Applications and Selection of Receiving Diodes
THx-RNMarsh
THx-RNMarsh
Interestingly, the quietest red LEDs I've found were the HLMP6000, which are pretty tiny. Lowest impedances as well, so there may be a relationship.
The physical package says nothing about die size.
For normal low power LEDs the die size is normally ~8mills square.
These covers the normal 3mm, 5mm but also SMD packages.
Patrick
- Member Areas
- The Lounge
