Building my first speaker, advice
Im thinking about building my first speaker, I already have designed a vented box that is tuned around 40 hz. I want to put 2 Dayton audio nd105-4 4" drivers in the box and a plate amplifier, i was thinking about the Dayton audio SA25 25w. Would this be enough power for both drivers? Does anyone have tips for puting the box together?
I would appreciate your help!
BEYMA 8WOOFER/P-V2 pdf, VB = 85.0 L, FB = 28.0 Hz
F3 (in room): 23.5 Hz
Ports (diam/length): 1x9.4 cm/24.11 cm or 2x7.4 cm/31.72 cm.
(Surfaces PS1 : 69.40 cm2, Surfaces PS2 : 86.02 cm2)
With the two port option, less chuffing.
It is a driver for 50W. If using at max SPL or having a very powerful amp 75-100W then ports should be calibrated for the same power or use the double port 3"-4".
Volume displaced by driver: 1.5 L
Volume displaced by (2x) 3" ports: 3 L
Total driver + 2 ports : 4.5 L
VB 85.0 L net + 4.5 L = ~90 L
