F6 Illustrated Build Guide
ZM what I meant is how does this circuit produce the approx 4Vish ?
I understand that the voltage across the 5k pot is the same as the zener voltage and that the current thru the pot is 1.36ma as per your example but how does this translate into getting the desired Vgs?
thanks again.
Nash
The trimmer is the voltage divider for the Zener voltage.
You take the gate voltage for the mosfets from the trimmer viper.
My I use LU1014D at the output stage ?
Postage Only
I have a pair of line transformers from an HP 353C patch panel -- should work in the F6 -- you can see the schematic on page 26 of the manual from Agilent's website. I measured them and they are flat from 20Hz to 200kHz. Will send them out, US only, for the price of postage. (Should be $6 w PP fee).
