That looks good. What country are you in? In US ordering from Parts Express is the easiest and fastest way to get them.
From Indonesia
It took 10 days - 30 days. until orders are received.
From Indonesia
Wow!
And I have not bought the tc9 yet because I am in Taiwan and the shipping was more expensive than the drivers!
EBay was cheaper than going through PartsExpress?
Well, i might reconsider if you say it was worth it!
Wow!
buy from ebay id "www.speakeraddict", cheaper than partsexpress.
2 pcs speaker $25.80 , shipping $21.70
If anyone wants to try to make a Bluetooth wall mount speaker, you might try this rather than doing it piecemeal like me and having to deal with solving the ground loop noise problem. This is a good price for an integrated 20w class D amp and BT module with what appears to be playback and volume control buttons as well as speakerphone capability. This is probably the core of all the $200 BT micro boom boxes.
Online Shop Bluetooth amplifier board digital amplifier board module before and after the level amplifier board bluetooth amplifier|Aliexpress Mobile
Vifa TC9FD speaker has arrived.
still wait speaker box
You mean you have to wait to start building the enclosure? Good luck.
My friend will build enclosure for me.
Nice friend!
Making it out of wood or foam core?
Using 12mm MDF board, if MDF board enough, also make tabaq box
http://www.coolcat.dk/bjoern/TABAQ BOX Cabinet build.pdf
foamcore only in big city, must buy in large quantity
12mm MDF board (122 x 244 cm) only $11
unfinished vifantastisch, source PC Soundcard change op-amp with lm4562 power amp audiobah tpa3116 / tda7297 unmodded, sound good, detail, bass is ok, but too bright to my ears
Did you put the MLTL ports on or are you running it open ended like the original Vifafantastic? It sounded quite balanced once the MLTL ports were installed and playing against a wall.
I built a set this past weekend with TC9's and foam. They are great for TV speakers...much better than any soundbar I've heard. I picked up some MDF, so I'll make something more permanent.
Good to see the PS95 may also work, so I'll try one of those.
Any thoughts on one of the new Dayton PC83s in either to 4 or 8 ohm variety? The response looks wonderful on those in the specs.
- Full Range
- Flat Wall Mount Stereo MLTL using TC9FD's (2)
