TSSA V1.7 mosfet Current feedback amp module
All finished.
Thanks Sonny for such a great sounding amp.
Thanks guys. Im pretty happy with the way it turned out, kinda make it up as I go. Made shades for the LED's and tude so at night time there not so bright.
It gave me something to do while I waited for the kit to get here and such a good amp deserves a nice box.
Hello
Rogerchou.
I would but i have redesignet the frontend today.
The frontend did have 12dB gain. It is not reduced to 0dB and the attenuator is changed to -80 to +12dB instead of -90 to 0dB.
I was a bit worried that an MM pickup would be able to hit the voltage Limit.
The MM pickup phono stage has 40dB gain. The attached is the riaa curve of the phono stage. It is a two stage design as i do not want to overload the frontend.
The gain is not ~59dB but 40dB. But the deviation fits.
The overload performance is 84mVrms@1KHz.
The opamps has jfet inputs and resistors is in worst case 10K. So noiselevel will be low. Capacitors are 330nF, 100nF and 10nF. AC coupling capacitor is polymer.. Same type as in the AK4490 DAC and the TSSA V4/V8 amp.
  • dual opampfoldedcascode stage riaa curve.pdf
