Sony VFET Amplifier Part 2
Joined 2012
no , you aren't
to quote one handsome and overly clever chap :
:clown:
nope
however - his Sony amp is Demonstration of Force ( as many other recent pieces are)
for moi - using them as followers = waste of parts - considering that he's able to make the same with plain dirt mosfets
I'm not sure will he admit that , or not
That's an even bigger Quote from other thread.
Does this mean that in this follower configuration the VFETs don't make the sound?
But the new front end is giving this amp it's sonic signature?
Papa wrote in Part 2 "But the big Sony VFET amp project showed that they have something to bring to the table with push-pull topologies as well." Although nothing specific on follower mode....
(BTW not so fun if the same can be done with ordinary MOSFETs ;) )
Another thing, the voltage gain is developed in stage two with the 2SJ313/2SK2013 MOSFETs. Could not this have been done with JFETs also? Correct me, but I seem to remember Ernö Borbely did something like that with some parallelled 170/74s? But, maybe the MOSFETs simply are better in that position.
Official Court Jester
Joined 2003
not exactly that VFets (OS) aren't contributing to sound
(with some luck you'll find Papa's THD graps for sole VFets source follower stage ; compare them with , say , F4 THD graphs)
however , same as I am inclined towards blissful ingeniousness and wittiness of M2 (Jfet buffer +xformer+Mosfet source follower) I am more inclined to simple (well known) Mosfet source follower stage than to (preputium made of) already ultra rare Sony Fets in same role ; it's better to use them in common drain config , so having greater character exploitation
( I have some , so I'm not talking here about sour grapes)
Pap's goal is to explore and to present to Greedy Boys ;
but , my own goal wa sand still is to make as many permutations/iterations I can-for learning purposes , but I'll always choose by my own preferences
previous Mithrandir's spells aren't worse than (most) present one
:clown:
Joined 2009
I think the new toy Papa gave us is a unique combination of best driver stage and an output stage even his commercials don't have…….
Hope that I am right in the last point, I do not know what his Xs Amps use as Semis.
I think it is a unique chance to build something very fine….
and because M2 is out of production I hope that Mr. Pass will give free sometimes the circuits and we all can share Zen Mods experience too….
The one and only
Joined 2001
It is certainly true that there are interesting things about the front end that
have nothing to do with the VFETs, or for the output stage in general. You
can easily apply this circuit to another follower output stage.
Toshiba Mosfets 2SJ201/2SK1530 or 2SJ618/2SK3497 would make fine
output stages, and lacking those, IRFP240/9240 would work. They would
require matching and some Source resistors, say 0.47 ohms, but they have
one advantage in not requiring regulated supplies.
For that matter, if you use switching supplies (intrinsically regulated) then you
could get rid of all the regulators in the circuits.
The question of single vs dual VFETs is germane, and I pulled up some curves
made some time ago for 8 ohm distortion vs power without feedback.
Keep in mind that the horizontal scales of the two curves are not matched,
and there is noise in the test setup on the singles.
You will notice about twice as much thd, but applying feedback will take that
down arbitrarily.
QUOTE]
So the BA-3 output stage /F4 could be driven by the front end without any changes to either circuits?
