Source for output air cor output inductor??
I've been winding my out ouput inductors. 16AWG, 1-2uH. While this isn't especially difficult, my "craftmanship" isn't the best looking. Search as I might, I cannot find an "off-the-shelf" source. (If I wanted to order 100-1000, that might be another situation!)
Is anyone aware of a source for ready made output inductors? Must be air core and 18-14AWG, 1-2uH.
Yup. Pretty much what I've been doing. I've also just discovered that using the theads on a bold of the appropriat diameter and thread-pitch is helpful. Too bad some clever soul doesn't make a 10-ohm resistors specially dimentioned to use as a form. I've made this work on low powered amps, but on higher powered it doesn't work out.
Well, it is not air core, but Reichelt sells Fastron inductors per piece. I think these will do with 3.9uH, 12A.
Steven
"The low values required for an audio amplifier can be wound on a 2W resistor, any value. "
Well, that's true up to a point. But if I'm anticipating a 100W-150W @ 8 ohm that also can handle a 4 ohm load, I prefer using 16AWG magnet wire. My Wheeler's formula calculator tells me I need a larger diameter and/or length than any 2W resistor I know of has. 18AWG would do it but could get a bit hottter than I care for. I tend to be convervative about wire guage, heatsinks and thermal maters, generally.
I just dug up this old thread. I made and installed the output inductors. But I am a little concern. I used 14 gauge insulated wire and wound 15 turns on an AAA battery. It's already installed on the pcb. I have second thoughts whether that is optimal.
Is 15 turns too much inductance winding on an AAA battery? Or I should reduce a few turns?
Joined 2010
The value is not critical and some here use dangerously low values - should the amplifier be used with unknown/nasty speaker loads.
OTOH, the value should not begin to reduce bandwidth either, if you imagine you need >>20 kHz. I suggest beginning at 3uH and reducing according to your final design testing which, as it hasn't built yet, should still be up for amendment.
I have seen pictures that people use 10 turns. I guess 15 turns should be a good place to start even it's 1.2uH from the calculator.
