My Holton amp builds.
Audio Research look case with PassLabs look heatsink
200VA 2x18v
50VA. 2x24v
PowerOne R3.0
40pc Vishay 2200uF 63 volt caps for each channel.
I played a couple of days with the 20L on my Infinity RS1, supprised how good it sounded on them. Sensitivity is around 85-87db.
People ho is around for a class A amp, no need to look more. The 20L is the solution, ore the 50L if you looking for more power.
Realy hungre speakers ? Buy 4 50L. 2 boards for each channel when using xlr pre.
+ signal for one board and - signal to the other one and ground to both. 100 watt class A should make almost any speaker sing. But the wallet will hurt a bit ��
New projeckt in order :)
Bridge 50L boards. 2 boards for one channel using xlr innput.
2 monoblocks with some pass look chassis.
Alot of Nichicon KW 2200uF 63 volt caps is ordered.
One special ordered toroid 630VA 2x25volt, built on 800VA core, can deliver totaly of 18 A.
For the innput 120VA 24volt.
Around 60 capacitor for each channel. Making 66000uF.
I love the new case you got Oyvind:)
Where on earth did you find a Pass Clone chassis?:D
Cheers Anthony
