Schematic for reference
Lose wire or a bad tube or tube socket . . .
http://elektrotanya.com/PREVIEWS/63463243/23432455/peavey/peavey_classic_30.pdf_1.png
All these are good suggestions, also could be a cold solder joint making intermittent contact with heating of the circuit. You could have loosened a solder joint for the tube sockets when removing or replacing the tubes. This is a printed circuit board amp, so this is also likely.
I have one of these amps right now all opened up for similar issue, the amp has multiple cold solder joints on each power tube socket.......even the preamp tube connections look bad. I removed all the old solder and resoldered the tube sockets.
On a side note I might be starting a seperate thread about these amps, I have found a couple of strange RC networks on the normal channel before the signal even gets to the tone stack. R8 and C9 cut the lows and I believe the local feedback around V1B attempts to tame the highs Seems like confilicting tone control but maybe my foggy brain isn't seeing things correctly. I plan to put more time into making the clean channel sound a little better than it does. I think it has potential but even after a speaker change the highs are just too ice picky for me.
Intermittent heaters in the EL84s would be pretty rare.
The tube heaters are in series. If you look at the schematic, there are a couple of resistors in series with the string. They are on one of the three boards, while the tubes are on another, and the power comes into the third. If you look at the two resistors, they are wired to short bare wire jumpers over to the other boards, two at each end. The little jumpers can crack and break, the resistor solder can fail, the jumper solder can fail. Those are the most common causes of your symptoms. Look especially for discolored solder in those areas, when the connection fails, it often gets hot, further degrading the joint.
Whenever you are inside one of these amps, it is a good idea to gently tug on each and every small bare wire jumper to reveal if any others are broken.
The Classic 30 is a fine little amp, very popular. yes, it is better to start a new thread to discuss its circuitry so as not to confuse this repair. If you go to BlueGuitar.org there are a bunch of modifications that have been done to this amp, you may pick and chose from those.
I wish I had some photos of the resistors I described.
Ask and you shall recieve
Topside view I labeled the resistors and circled the jumpers in blue. Underside view I circled where the resistors and jumpers get soldered too. Hopefully this will help him sort the problem out and or future people with the same problem.
- Live Sound
- Instruments and Amps
- Peavey Classi 30 cuts out
