wow - your hobby ain't tubes, it's painting !
You are right, I just like to put these things together. I don't know anything about tubes, just following the instructions and so on...
But I got this thing finished today:
How about this for tube project:
https://www.gearslutz.com/board/high-end/999222-tube-mixer.html
Cheers
Ian
Cheers
Ian
Joined 2009
the rest of us might as well give up and go home!
hllbll,
Fab job with the painting and finish - a unique looking amp you have there!
How does it sound?
Thanks. It turned out quite fine. And sound, it is just great. I was little bit worried how it would handle the lower frequencies, but no problem there at all. I'm not so good comparing different equipment, I just like it or not
Don't do that, no need for that. I just put these things together, some of you can design your own amps and put those together.the rest of us might as well give up and go home!
Tube amp by night:
And for the first time ever, I managed to get the goldleaf just right. Gold size was just properly dried when I applied the goldleaf. Well, at least at the second try it was, had to wipe the first one off because the gold size wasn't dry enough. Goldleaf just "smeared" and didn't stick properly.
Well what can you say..I have trouble with letraset ..
It looks great..how long did the finish take?
M. Gregg
M. Gregg
I guess I would have troubles with letraset too Of course I have applied the decals with the model kits, but... Well, all you need is more training, if something feels too difficult I made the stencil with the vinyl cutter and used that when applying the gold size. It's much easier that way, than lettering by freehand.
The painting itself took about three hours excluding the goldleaf. The final assembly and wiring and checking + re-checking, maybe two workdays. I did that at work, so had to do some "real work" at the same time. But I guess it can be easily built in one day if you can fully concentrate for the job and have nothing else to do.
Also I got some extra challenge, because I was the first one to purchase this kit as it is at this time. Previous version was mechanically slightly different, as you can see from the manufacturers home page: UralTone amplification Web Store
There wasn't any major flaws with the design, biggest "problem" was the turret board, which wasn't meant to be with this kit, so I had to modify the turret board slightly that I got two tubes moved little bit more to the center. You can see the modification at the inner picture. Manufacturer did send me the right turret board, just in case something would have gone totally wrong, but didn't need that, luckily. At that time I had all the components soldered...
Or this one from Dr. Crazy Joe (PHD ee)Welcome to DoctorCrazyJoe.com, the OFFICIAL website of Dr. "Crazy Joe" Tritschler and your EXCLUSIVE source for Crazy Joe LP's, CD's, downloads, and more! From Tritschler Precision Engineering.How about this for tube project:
Cheers
Ian
How beautiful!
RIAA preamp output transformer
Wow!
Would you mind sharing the scheme?
Thank you!
based on schematic made by Davorin, two monoblock PPP with four 6GF7A`s, 12-15W output ... just finished
smaller triodes are used for phase splitter and cathode follower driving bigger triodes in output... all in all, triodes... 16 of them
based on schematic made by Davorin, two monoblock PPP with four 6F7A`s, 12-15W output ... just finished
Very nice well done
- Tubes / Valves
- Photo Gallery
