Post your Solid State pics here
Poor man OPS and IPS is running, IPS is only 35mm x 60mm. Overal amp performance is really good.
Thumbs UP for OS!!!
Thumbs UP for OS!!!
You like that "supercharged" harmon kardon OPS , huh ! I see you made
a "baby" CFA (X).
There are a lot of those out there (maybe as many as vssa ??) :D
PS - see the nice overload behavior - "kypton C"(cfa) has almost "rounded"
better clipping - like a valve.
I don't play around !
OS
Thanks OS
I really like it !!
It is saving a lot of time, really massive amout time is saved with this aproach. I will have to fine tune the temp compensation (which is working really quick !!). I have used predrivers with hfe around 280, sanken drivers hfe=300 and NJW0xxx with hfe=110 so the current gain is massive.
Mr Self magic resistor is working fine too.
I have made IPS from my last small project (I like it a lot).
Now I am preparing CFP OPS with 2 pairs of outputs, I do not know and can not explain why but it was sounding very very good with CFP output (with 20mA bias only).
THX
Peter
Thanks OS
I really like it !!
THX
Peter
Nice work!
How much compensation did you need in the output driver stage (C7,C8)?
Nice work!
Thanks.
I haven't made the board yet, I hope by the end of the week I will know.
With my previous CFP-Mad amp I have used 22pF, I think that 10pF would be sufficent enough, the config was 2sc5200/2sa1943 and drivers were bd139/140 -16. With 22pF it was rock stable.
In the new board I have made a room for degeneration resistors in CFP stage so it should help a bit.
Gentlemen, I would like and show you a picture of my current SYMASYM-build.
Most of the parts that you can see on the attached pictures are "DIYed".
The case has been built by my carpenter-friend Gerhard.
The SYMASYM-integrated-amplifier consists of:
- two DUAL-Mono SYMASYM Black (Green!) - Beauty SYMASYM-PCBs
- Mains Schaffner-filter being followed by a mains-DC-filter and Soft-Power-On
- 4 x 25 VAC torroid transformer rated at 400VAC
- My VCPRe (doing the source selection, attenuation (via LDRs), .....)
- Every functionality can be controlled via a IRC - unit
This build is using the small SANKEN TO3-P output transistors 2SC3263/2SA1294, and the "Allegro-SANKENs" play "like a divine".
I am currently thinking about which INTERNET-interface to add to this amplifier to be able to listen to INTERNET-radio and which DAC and Multimedia-player-software to add to be able to listen to my 1TB of my ripped CDs.
Best regards - Rudi_Ratlos
