Recommendations for phono preamp build
I forgot to add pictures.
Spend a lot less money and look at Boozhound. For the price it is worth a shot even if ultimately you go for something more expensive (I didn't say better.)
I was looking at the boozehound and it looks like a pretty good candidate. Minimal parts, simple design and high quality. I wonder how good it sounds? I would have liked to see some specs published.
Most definitely, based on many years with a Pearl 1.
jeff
The Pearl 2 has a lot more parts than the boozehound, but the specs are published and the design is discussed in detail. It wasn't designed by the legendary Nelson Pass, but it has the Pass DIY endorsement. There are instructions to tweak the circuit for MM or MC, so only one board required per channel.
The standard circuit has 55dB of gain with another 10dB available with some component substitution. Since I will be using it with the B1 buffer and a low output MC, gain is a factor.
The MM boozehound only provides 40db of gain, but you can pick up an additional 30dB with the MC kit. Also, the boozehound wants a 12-24V power supply, so I can run it off the same supply as the B1. The Pearl requires it's own transformer and PS.
I highly recommend the Salas folded phono stage with shunt regs.
Boozehound is OK, doesn't do MC without a step-up. I've had both, the Salas is superb.
+1
It is also a good match with the DCB1, that is what i use. SY is right, so read the build guide carefully to select components that suit your cartridge.
To answer SYs question, the Zhelter 901 is supposed to have an output impedance of 20R, but i don't know the DCR.
Also, the Paradise phono stage seems to be getting a lot of attention here. If I had to make a choice...I would probably go with the Salas or the Paradise if cost is not a concern.
For what it's worth, the boozehound is happiest at 24V and likes a very clean supply (i.e. batteries). And you will need a step up. The Salas can be built for MM or MC w/no step up. The Phonoclone and Paradise are MC only I think.
What amp/speakers you using? I didn't have alot of luck with a passive pre and vinyl. Even a buffered passive. Just didn't have enough drive for my Pass F5 and 90db-ish speakers.
The DCR is important here for looking at what sort of input device/topology would be best (for most MCs, the impedance = DCR). If it's well less than 10R, you have a good dynamic range at 0.5mV@5cm/s, so you'd want something with a bipolar input using devices with low rbb. Over 20R or so and paralleled FETs might work without too much noise degradation.
I'm partial to balanced cartridge operation and good quality SUTs, but reading between the lines of the OP's question, that doesn't seem to be among his initial choices.
