L'Amp: A simple SIT Amp
Joined 2013
hello,
I would like to thank who have made the project possible and helped me at all.
The Amplifier are great, better than I had thought.
If the lower values of the amplifier ok.
Temperature after 3.5 hours. Measured directly on the housing of 2SK82 83 ° C.
Heat sink 50 ° C
Voltage from 21.5 to 21.8 volts
Bias -5.5 volts
Greetings Dirk
Hallo,
ich möchte mich bei allen bedanken die das Projekt möglich gemacht und mir geholfen haben.
Die Verstäker sind toll, besser als ich gedacht hatte.
Sind die unteren Werte des Verstärkers ok.
Temperatur nach 3,5 Std. direkt am Gehäuse des 2SK82 gemessen 83°C.
Kühlkörper 50°C
Spannung 21,5 - 21,8 Volt
Bias -5,5 Volt
Grüße Dirk
Official Court Jester
Joined 2003
you have 83C at transistor; way too much for my liking
give us temperature directly at L bracket near transistor and temperature at main heatsink near L bracket
do you have temp. conducting grease between transistor and L bracket , same as between L bracket and main heatsink ?
from pictures it seems there isn't temp. grease ......
Joined 2013
