100W Ultimate Fidelity Amplifier
Thanks guys,
I have a 5k trimmer in the offset and 500 trimmer with 680R resistor in the vbe. I didn't realize they even make a 4.7k trimmer. If it is important I can order some. I have the boards ready except I am waiting for some 0.68R 2
3W resistors. As soon those arrive I will be testing. Thanks for the help.
Blessings, Terry
I finished my second A33 amp. Both tested +/-40V, single pair of output transistors.
I'll place them in an old audio amplifier housing.
The sound is very good for my taste.
Thanks Mr. Mile for amplifier schematic , Mr.Alex for PCB design
Tested Apex AX9 today with OPA2604 opamp and its :sing:. I like the sound on my PC monitor speaker currently I'm playing it with Apex NX-14. :cheers:
  • Apex AX9 1.02 Copper multiple layout 2 x 3.pdf
  • Apex AX9 1.02 Copper Single.pdf
  • Apex AX9 1.02 Silkscreen.pdf
  • Apex AX9 1.02.pdf
:D
Nice work, can you post picture of housing amplifier?
I will.
Looking for a large enough, simple, vintage housing. I'm thinking of dual mono with 2 traf of 180watt each. I have the traf, and I think 180 watt traf for each channel is more than enough for what I need. (46V +/-)
90% of listening time is under 1watt for me, the rest is:D:D
Regards, Laur
Hello guys
I have an idea because I always have the problem where I can place the power supply board on the case, so I place a capacitor bank and RL on the PCB to see how it looks :)
those caps are 22,000uF 63V so far I like the idea what you guys think ?
Juan
