The Aleph Design Reloaded
If I were to build another Aleph of any flavor I would definitely include Allen Newby's elegant clipping mod. I'm not sure if the mod produces an audible difference, but it's simple and it's an improvement. Unfortunately his web site doesn't want to come up for me. Maybe someone else might have better luck.
http://www.diyaudio.com/forums/pass-labs/115674-aleph-clipping-mod.html
Graeme
Official Court Jester
Joined 2003
Are there any updates for the original Aleph 0
yup
later Alephs
:clown:
Graeme
agree ; zenner diode is easy to add
if for nothing else , for better sleep certainly
Capaciitor 5mm and 7.5mm
Mosfet 6mm edge
XLR and RCA input
better?
Mosfet 6mm edge
XLR and RCA input
better?
Add additional holes to +/- 25V & GND to accept larger 14/16ga wires. I'm not sure how thick your heatsink plate is, but you might want to try and separate your output mosfet pairs a bit more for thermal spreading purposes. If you have a 3/8" or thicker plate it probably will not matter.
Also slide the 1nf cap near the input LTP to the right or move the 10k resistor to the left.
