Aikido 12VAC Help needed
For anyone who has built it, what is the value of C1? I dont see it listed in the manual.
Moderator
Joined 2011
On the posted schematic C1 sits between R12 and R10. In parallel to C11 and C2
Oh yes, that's the hum canceling circuit for the current sources. It passes hum from the B+ to the two grids through the resistor divider.
The C1 should set a corner of 5Hz or less (so as not to cause too much phase shift at the hum frequencies) with the series sum of R13 and the resistor below it.
That resistor is misnumbered as R10. It is not the same value as the two R10 grid stoppers.
