I am alleging the opposite.
But if you have dirty DC and bring that dirty DC to the inside of the sensitive amplifier without filtering at the entry to the screening chassis then expect interference to affect your internal circuits.
Sometimes that interference will be audible.
But trying to filter the interference too early leaves the cables still able to pick up interference. And then to inject that interference to sensitive circuits once the cable enters the screening chassis.
You have two different jobs when the circuits are susceptible to interference.
Make the DC good. Adding an RC at the PSU end is good, provided the final C is adequate to maintain a stable non varying DC.
Add an RF filter to EVERY cable that enters/leaves the screening chassis/case.
And for good measure if the susceptible circuits have a changing current then good decoupling at the circuit is required.
None of this has anything to do with
Nice Andrew.... Hehe I almost believed you had lost your sense of humour....
Anyway I stand with my statements as they only apply to my builds.... I have good clean DC coming out of the psu, I use shielded cable to transport it into the riaa amp, I decouple it locally (but not with large caps) and in reality I can really hear differences when I fiddle with the smoothing caps in the psu.
As a matter of fact, I just reduced the 56nF bypassing the 10000u AG to 12nF and lost some mid freq glare. The difficulties lies on choosing the right value for bypassing.... One must aim at clearer sound but without proéminences.
I believe smaller caps intrude latter in the freq band..... The higher the capacitance, the lower in freq you intrude.
Just to prove I always take you seriously, I do consider these statements as best practice for ALLYou have two different jobs when the circuits are susceptible to interference.
Salas max. Vin for FSP reg is 45VDC?
Up to 48, 50, 52, (real max is 55 on high mains hours) if you must due to some over-spec mains and/or high Tx. 45 is alright keeping the CCS MOSFET cooler.
Start with 54mm sinks. But keep a couple of 15R low ppm 2W in hand. In your situation using a single input JFET with high value source resistor, its bias drift tendency with ambient temp is very much reduced. So use a criterion of no more than 50C average internal air temperature with a ventilated lid put on (drill few holes under and over each sink's vicinity). You maybe have a K thermocouple wire or kitchen probe to monitor that. Allow for summer room temp usual rise in your location. Good you had tangible subjective improvements. It took you enough precise work to make those nicely populated matrix board regs.
Update on the bigger sinks: I've got the 54mm sinks in. It's cooler but still pretty hot. I can hold my finger on them but not over 5 seconds. I may have to go to the 15ohm resistors. I am assuming this will change V out?
the "glare" if it existed may well have been interference !Nice Andrew.... Hehe I almost believed you had lost your sense of humour....
Adding low esr capacitors across PSUs is a risky business.
That is why we see so many now suggesting using snubbers.
There were many that did the wrong thing. I did it back in the '70s. But I was stupid then. I believed nearly everything that sounded "about right".
Very good advice Andrew, I use Quasimodo to snubber all my transformers, really useful device.
Do you guys know if Quasimodo PSB V4 is still available somewhere? I might need to build such jig for myself.
I use V4 through hole version and have V3 SMD version blank pcb with two BAT750 diodes only to be soldered.
Can you sale it?
Sent from my iPhone using Tapatalk
Really I have as spare, also I don't know how much I paid for it. Better to follow by PM.
Done.
Hi Andrew
Why is it risky to use low esr caps on psu's ?
What is the Quasimodo thing ?
A small pcb to measure ringing and lets calculate the exact values to damper the ringing resonance of any transformer.
http://www.diyaudio.com/forums/power-supplies/243100-simple-no-math-transformer-snubber-using-quasimodo-test-jig.html
You need a scope to make measurements.
What does R4 do (on the Tea-Bag FSP board)?
It needs adjustment depending on gain, I am building for MM 5mV input, the guide says 1.8K. I have 1.68K and 2.21K, or should I make a series pair to get the exact value?
Manual-guide says:
"For circa 5mV MM don't populate Q2, R3 use 91R R2, 5.6K 1W R13, 1K8 R4 for 40dB"
- Analogue Source
- Simplistic NJFET RIAA
