D3a SPICE Models
Triode-Connected
Pentode
Triode-Connected
Code:
* Generic triode model: D3A_PT_AN
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Tue Dec 24 08:47:57 2013
* Plate
* | Grid
* | | Cathode
.SUBCKT D3A_PT_AN A G K
BGG GG 0 V=V(G,K)+0.38087015
BM1 M1 0 V=(0.0021582473*(URAMP(V(A,K))+1e-10))**-0.28773641
BM2 M2 0 V=(0.83904987*(URAMP(V(GG)+URAMP(V(A,K))/74.574462)+1e-10))**1.7877364
BP P 0 V=0.03039942*(URAMP(V(GG)+URAMP(V(A,K))/88.879654)+1e-10)**1.5
BIK IK 0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.018902992*V(M1)*V(M2)
BIG IG 0 V=0.01519971*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK A K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.015714194*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK G K I=V(IG)
* CAPS
CGA G A 2.7p
CGK G K 7.3p
CAK A K 3.1p
.ENDS
Pentode
Code:
* Generic pentode model: D3A_AN
* Version 3.10, Generated on Mon Dec 23 07:04:01 2013
* Plate
* | Screen Grid
* | | Control Grid
* | | | Cathode
.SUBCKT D3A_AN A G2 G1 K
BGG GG 0 V=V(G1,K)+0.38087015
BM1 M1 0 V=(0.0021582473*(URAMP(V(G2,K))+1e-10))**-0.28773641
BM2 M2 0 V=(0.83904987*(URAMP(V(GG)+URAMP(V(G2,K))/74.574462)))**1.7877364
BP P 0 V=0.03039942*(URAMP(V(GG)+URAMP(V(G2,K))/88.879654))**1.5
BIG IG 0 V=0.01519971*URAMP(V(G1,K))**1.5*(URAMP(V(G1,K))/(URAMP(V(A,K))+URAMP(V(G1,K)))*1.2+0.4)
BIK2 IK2 0 V=V(IK,IG)*(1-0.4*(EXP(-URAMP(V(A,K))/URAMP(V(G2,K))*15)-EXP(-15)))
BIG2T IG2T 0 V=V(IK2)*(0.79212298*(1-URAMP(V(A,K))/(URAMP(V(A,K))+10))**1.5+0.20787702)
BIK3 IK3 0 V=V(IK2)*(URAMP(V(A,K))+4970)/(URAMP(V(G2,K))+4970)
BIK4 IK4 0 V=V(IK3)-URAMP(V(IK3)-(0.015714194*(URAMP(V(A,K))+URAMP(URAMP(V(G2,K))-URAMP(V(A,K))))**1.5))
BIP IP 0 V=URAMP(V(IK4,IG2T)-URAMP(V(IK4,IG2T)-(0.015714194*URAMP(V(A,K))**1.5)))
BIAK A K I=V(IP)+1e-10*V(A,K)
BIG2 G2 K I=URAMP(V(IK4,IP))
BIGK G1 K I=V(IG)
* CAPS
CGA G1 A 0.035p
CGK G1 K 4.1p
C12 G1 G2 2.7p
CAK A K 0p
.ENDS
Triode-Connected
PentodeCode:* * Generic triode model: D3A_PT_AN * Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved. * Version 3.10, Generated on Tue Dec 24 08:47:57 2013 * Plate * | Grid * | | Cathode * | | | .SUBCKT D3A_PT_AN A G K BGG GG 0 V=V(G,K)+0.38087015 BM1 M1 0 V=(0.0021582473*(URAMP(V(A,K))+1e-10))**-0.28773641 BM2 M2 0 V=(0.83904987*(URAMP(V(GG)+URAMP(V(A,K))/74.574462)+1e-10))**1.7877364 BP P 0 V=0.03039942*(URAMP(V(GG)+URAMP(V(A,K))/88.879654)+1e-10)**1.5 BIK IK 0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.018902992*V(M1)*V(M2) BIG IG 0 V=0.01519971*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4) BIAK A K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.015714194*URAMP(V(A,K))**1.5)))+1e-10*V(A,K) BIGK G K I=V(IG) * CAPS CGA G A 2.7p CGK G K 7.3p CAK A K 3.1p .ENDS
Code:* * Generic pentode model: D3A_AN * Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved. * Version 3.10, Generated on Mon Dec 23 07:04:01 2013 * Plate * | Screen Grid * | | Control Grid * | | | Cathode * | | | | .SUBCKT D3A_AN A G2 G1 K BGG GG 0 V=V(G1,K)+0.38087015 BM1 M1 0 V=(0.0021582473*(URAMP(V(G2,K))+1e-10))**-0.28773641 BM2 M2 0 V=(0.83904987*(URAMP(V(GG)+URAMP(V(G2,K))/74.574462)))**1.7877364 BP P 0 V=0.03039942*(URAMP(V(GG)+URAMP(V(G2,K))/88.879654))**1.5 BIK IK 0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.018902992*V(M1)*V(M2) BIG IG 0 V=0.01519971*URAMP(V(G1,K))**1.5*(URAMP(V(G1,K))/(URAMP(V(A,K))+URAMP(V(G1,K)))*1.2+0.4) BIK2 IK2 0 V=V(IK,IG)*(1-0.4*(EXP(-URAMP(V(A,K))/URAMP(V(G2,K))*15)-EXP(-15))) BIG2T IG2T 0 V=V(IK2)*(0.79212298*(1-URAMP(V(A,K))/(URAMP(V(A,K))+10))**1.5+0.20787702) BIK3 IK3 0 V=V(IK2)*(URAMP(V(A,K))+4970)/(URAMP(V(G2,K))+4970) BIK4 IK4 0 V=V(IK3)-URAMP(V(IK3)-(0.015714194*(URAMP(V(A,K))+URAMP(URAMP(V(G2,K))-URAMP(V(A,K))))**1.5)) BIP IP 0 V=URAMP(V(IK4,IG2T)-URAMP(V(IK4,IG2T)-(0.015714194*URAMP(V(A,K))**1.5))) BIAK A K I=V(IP)+1e-10*V(A,K) BIG2 G2 K I=URAMP(V(IK4,IP)) BIGK G1 K I=V(IG) * CAPS CGA G1 A 0.035p CGK G1 K 4.1p C12 G1 G2 2.7p CAK A K 0p .ENDS
Super! Thanks for the quick reply.
Cordell Models/Mosfet Modelling
Can someone point me in the right direction on how do use the following models posted. Or for that matter, how to use an external transistor or mosfet device.
Do I need to find the set of symbols for this or use the ones in LTSpice?
* Cordell Models - 04/20/2011
* copyright Cordell Audio April 2011
Look here:
http://www.diyaudio.com/forums/soft...-ltspice-beginner-advanced-5.html#post4134695
Does anyone have a collection of all the latest and most accurate models for LTSpice? I was looking for a 12AU7A model.
There are tons of tube SPICE models in this "sticky" thread:
http://www.diyaudio.com/forums/tubes-valves/243950-vacuum-tube-spice-models.html
I've found the triode models from Ayumi Nakabayashi to be as accurate as any. Here is a workable model for the 12AU7, which should get you started. Note that the model is named 12AU7, and not 12AU7A. The "A" suffix isn't important here.
Code:
* Generic triode model: 12AU7
* Version 3.10, Generated on Sat Mar 8 22:41:08 2008
* Plate
* | Grid
* | | Cathode
.SUBCKT 12AU7 A G K
BGG GG 0 V=V(G,K)+0.89005722
BM1 M1 0 V=(0.028826571*(URAMP(V(A,K))+1e-10))**-0.90897681
BM2 M2 0 V=(0.622671*(URAMP(V(GG)+URAMP(V(A,K))/13.089625)+1e-10))**2.4089768
BP P 0 V=0.00087237591*(URAMP(V(GG)+URAMP(V(A,K))/21.021735)+1e-10)**1.5
BIK IK 0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.00055330711*V(M1)*V(M2)
BIG IG 0 V=0.00043618795*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK A K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.00049917061*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK G K I=V(IG)
* CAPS
CGA G A 1.5p
CGK G K 1.6p
CAK A K 0.4p
.ENDS
Still looking for models of soviet 6P9 (6Π9) output pentode and 6F5P (6Φ5Π) triode-pentode ?
Does anybody have ?
Try this for 6P9:
Code:
.SUBCKT PENT_6P9 1 4 2 3 ; P G K G2
+ PARAMS: CCG=13P CGP=0.06P CCP=7.5P RGI=2000
+ MU=30.4 KG1=275.7 KP=91.4 KVB=23.3 EX=1.15 KG2=4500
* Vp_MAX=480 Ip_MAX=80 Vg_step=1 Vg_start=0 Vg_count=7
* Rp=1600 Vg_ac=23.5 P_max=9 Vg_qui=-23.4 Vp_qui=240 UL=0.43 EG2=150
* X_MIN=33 Y_MIN=41 X_SIZE=368 Y_SIZE=239 FSZ_X=1053 FSZ_Y=709 XYGrid=false
* showLoadLine=n showIp=y isDHT=n isPP=n isAsymPP=n isUL=n showDissipLimit=y
* showIg1=n gridLevel2=n isInputSnapped=n
* XYProjections=n harmonicPlot=y harmonics=y
RE1 7 0 1MEG ; DUMMY SO NODE 7 HAS 2 CONNECTIONS
E1 7 0 VALUE= ; E1 BREAKS UP LONG EQUATION FOR G1.
+{V(4,3)/KP*LOG(1+EXP((1/MU+V(2,3)/V(4,3))*KP))}
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1*ATAN(V(1,3)/KVB)}
G2 4 3 VALUE={(EXP(EX*(LOG((V(4,3)/MU)+V(2,3)))))/KG2}
RCP 1 3 1G ; FOR CONVERGENCE
C1 2 3 {CCG} ; CATHODE-GRID 1
C2 1 2 {CGP} ; GRID 1-PLATE
C3 1 3 {CCP} ; CATHODE-PLATE
R1 2 5 {RGI} ; FOR GRID CURRENT
D3 5 3 DX ; FOR GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
Beside the small typo in Dmitry's code (pins should be 1 2 3 4 on the first line), the plate current seems to be way too high, could someone please double check, may be I did something wrong?Try this for 6P9:
I can't say anything about the typo. The model work as it is now.
I compared the simulated plate current to the triode curves from here:
http://www.mif.pg.gda.pl/homepages/frank/sheets/113/6/6P9.pdf
I tried to follow the 50 mA anode current line by the following voltage settings and got the currents:
1. Ua = 102 V, Ug1 = 0 : Ia = 40 mA
2. Ua = 171 V, Ug1 = -3 : Ia = 38 mA
3. Ua = 242 V, Ug1 = -6 : Ia = 38 mA
So my results show too low anode currents.
Please look at the pin numbers used in the SPICE code, they do not match up to "1 4 2 3 ; P G K G2", they should be "1 2 3 4 ; P G K G2". Please try changing the pin numbers and see if the triode curves match up with the datasheet.I can't say anything about the typo. The model work as it is now.
- Tubes / Valves
- Vacuum Tube SPICE Models
