did you put an ecap on those voltage dividers lifting the filaments?
Hello Ajt,
I put in a 100uf cap at the lower end of the divider after the first clc filter not the last one... will using a higher value capacitor on the divider and moving it to the last LC help?
Thank you
Try like a 1000 uF min 50 V on the lower resistor in the divider. Ie between center of divider and ground.
I will try as you say... I think I do have that value.. also should I move the divider at the last LC filter of the supply?
I am using clclc supply..
Thank you for the help
No. Keep it early in the filter. Otherwise you will get AC on B+
Hello Salas and all,
I very much would like to dc regulate the heaters... Id llike to get rid of the noise...I only have a 5.7 v ac at 2 amp and 6.7 vac at 1.5a winding available... will it still work?
Thank you
You can put those in series and you'll have more then enough voltage for regulated DC.
And just share the single supply for both the heaters?
Ty
Ty
Yea. You could use 2 regs on one feed. If your gonna make as Salas 317 CCS I recommend choosing the series settings resistor size very carefully. 6V6 is just a spec and when controling voltage with current different tubes will vary alot.
I did some experiments on that way back in posts.
Hello guys,
Is it okay to put a virtual center tap from the heaters to the ground with two matched resistors even if the heaters are elevated?
Thank you...
No. Then you first reference heater center to ground and then to your elevated voltage. You can put the virtual center to your elevated voltage on the divider tho, or just skip the divider/elevating and tie it to ground.
If it does your thing, one 200 or 220 k from each filament secondary could be upper resistor and the decoupled 10 k could be lower in your voltage divider.Thank you stajo... will do that and report back...
Best regards
I am considering trying a 6ax4 graetz PSU for my rebuild. I have the chokes and caps, so why not. Wandering if I am correct in assuming that I will drop about 15-18V across the 6ax4's for about 80-100mA of current needed for dual regulators. Do I need to quadruple this if using a graetz configuration. Here is the schematic I am using.
http://1.bp.blogspot.com/_ZXzBbxBRj...c/i_zXDoVqTHw/s1600/6CB5A-PSU-Graetz-6AX4.jpg
Perhaps a better question. How important is the setup before the SSHV2. Does it negate fancy PSU setups?
Thanks. I'll start a thread about the 6AX4 V drop. Want to get the right transformer.
Your amp will draw some 30 watts of 6,3 V rectifier filament power. Have a sturdy tranny for that?
Sheet says 32 Vdrop per tube http://frank.pocnet.net/sheets/049/6/6AX4GTB.pdf. My guess is that your drop will be somewhere there.
Graph at the bottom seems to show that Vdrop is dependent on current through diode, same as with SS. I may be reading it wrong. Two SSHV2 will far roughly 100mA if we go for double the channel bias. That seems to correlate with a 17V drop across the diode/tube. Lundahl 1650 has 4 6.6V windings at 3A. Use two for rectifier, two for 6v6 regs. Also have two Antek toroidal that could provide similar configuration. I want this to be the last time. Have cases designed for main box, just working on PSU box.
- Tubes / Valves
- 6V6 line preamp
