CDROM:The cheapest CD transport with great sound
The CD (or any other optical storage disk for that matter) is very jittery, because of material tolerances.
But all this doesn't matter at all. After the laser has read the information on the disk and an electronic digital signal has been created, it goes into a fifo buffer before going to the actual dac. The fifo buffer output and the input of the dac should be very close together, millimetres mater a lot here, and its this clock here that determines the performance of the dac.
And I agree with Marce: Jitter is a non issue in modern converters.
I am not saying jitter is not a problem and I am not saying it is voodoo, what I am saying is; is it as bad as some make out in audio, I see figures in ps, often must smaller than I have seen for other fields of electronics.
Personally I don't use CD transports any more I have all my CD now ripped to hard drive, as I think it is a better option...does It sound better, I perceive so...:)
My argument is that getting a few bits of data down a metre or so of cable should not be that hard, and if different drive sound different then there is a serious engineering problem in the chain.
Hiya Julf, gutted another engineer is in Belgium (so no Christmas market for me:mad:) as I was stuck working on a big job for these (and still am 4,000 connections analogue/digital layout!) HedoN, which I why I probably got confused over distance as these are near the port. Hopefully next year, though I am trying to get a visit to Hedon.
Are there any currently manufactured drives that sound good?
CD transports don't have "a sound".
Its the DAC that matters, there the digital signal is converted into a signal we can listen to.
It could be that the DAC designer has no clue on how to properly design a DAC, witch happens a lot in high end audio. These awful DAC's have no jitter reduction build in like PLL's or ASRC and there it is very likely that you can hear a difference between transports. But its a faulty design and anyone interested in good sound should reject these devices.
