Circlotron on field-effect transistors with a stabilization system modes.
Hello colleagues, I propose to discuss the scheme CIRCLOTRON ON FIELD-effect TRANSISTORS WITH a STABILIZATION SYSTEM MODES.
Scheme circlotron is not going to. Preparations are under way. Drawn PCB output stage. Your card is already collected. Here is the schematic. Please feel free to contact if you have any questions.
Hello FEDOSOFF. I hope that you are well. I am glad to see that you are expanding the use and value of your patent application. Please explain the symbols of the "diodes" in the circuit of the Circlotron. Also, pls clarify the connections at the loudspeaker; they cross on top of each other! Thanks
I need to study [carefully] your schematics above so as to appreciate and grasp their workings and value.
Best regards
Antoinel DIODES INDICATE THE POWER SUPPLY. Scheme circlotron has no singularities except system balance control current. The Converter current voltage showed good results. For example, if 10 volts output ( RMS ) harmonic distortion was 0,008%. Please feel free to contact if you have any questions.
Well boys, any generic three stage amplifier, like Blameless for example
Can offer you the same or better performance without all that complication.
I suggest you boys, to check together your psycho analist the reasons why you choose to spent time and dedicate yourself into an overcomplicated design to achieve the same performance already obtained by hundreds of earlier and much older designs.... , more complicated and offering you worse performance considering specifications.
Overcomplicated design does mean an overcomplicated mind...and not someone that is wise... and because wisdom, can create such confusion..... straight line is still the smallest and closest distance between two points... despite we do not have straight line in the universe due to gravity..but we can simplify...or not?
I hope it is just an exercise, to have fun achieving same result with overcomplicated circuit....because if different than that, you may spend a lot of money and time to heal from that together a psycho analist layed into a couch.
Just to remind folks....now a days, forum amplifiers, a lot of them, are high efficient and THD is not more than 0.000150%
regards,
Carlos
regards,
Carlos
Nonlinear distortion in such schemes and harmonic suppression depend on the accuracy of the balance of currents. Also, do not always 0,000 % will correspond to a good sound.
Hi Carlos,
This thread is not about THD. This thread is about the balanced current-coupled architecture. Some people don't understand / don't bother / too lazy / don't care exploring it. Fedosoff does care. And this is a very wise approach. Then it maybe blameless or whatever - doesn't matter. What matters - it's balanced and it's current-coupled with the source.
If you saw the video about Fedosoff's earlier development - class A amplifier with waterfall-kind-of cooling - well, you know, some DIY builds cost the same as a decent car. That one costs the same as a small apartment, from my perspective :D Plus you need to build a private power plant nearby ;)
So what? That's his choice. I enjoyed watching, got a couple of ideas for myself - no problem ;)
Let there be more designs - good ones, insane ones, expensive ones, cheap ones - different ones!
Valery
Hello FEDOSOFF. The image shows a schematic of your differential 'improved current source" with modifications so as to possibly convert it to a Class A power amp; right there, and not wait to do it several steps downrange.
1. I increased the current transfer ratio [to the power output bjts] by a factor of 100:1
2. I used a voltage step down output transformer to couple power output to a loudspeaker.
3. I assumed one can do a "digital volume control" inside the DAC before its L+ and L- outputs are released to the outside world
Is this a viable option?
Best regards.
3.
