This is the first time I read of a truly interesting quasi-DIY DAC project. Congrats Soren, it has been since my experience with the Totaldac that i wanted such a project to show up.
Some have argued that R2R ladder DACs are prone in picking more jitter than ΔΣ ones. What is your opinion on this?
Also what is your opinion in software DSD converstion? Do you think that hardware is better or software will also do?
Tnx,
Panagiotis
Tnx,
Panagiotis
What would the advantage be? The max. resolution our ears can "hear" is about 21 bits... so why 32? Because it measures even better?Just curious, what would it take to turn this into a 32 bit dac?
I guess it gets to a point where all these bits and sampling, it be very hard to tell the difference in what your listening to.
1 bit - 11,2 MHz - DSD & UP
No, not any PCM but DSD at 256x would possibly become the very nearest in a Direct Hi Res PB A to B Comparison to the Mr. Tim De Paravicini's best modded Analogue STUDER C37 1/2'' reel to reel Master Tape Rec - PB Source, all the rest is way down there somewhere smeared in the Digital Fog of the Dictated Commercial Whatever Music Production.. But if the heavens wish exist to come close to the Tim de Paracini's best modded STUDER C37 - 1 inch Reel to Reel Tape . . . Then a lot in digital still need to be done . . . . .( I have a privilege to hear it at a Guy who collect best and rare vintage analogue stuff - Music was a live performance recorded on it, a Classic Chamber Orchestra. - Latter this same HiRes recording we played Back - Balanced - directly to Four custom made mono blocks all to directly drive the Apogee Scintillas without step up transformers )..... Yes, for this level of truthful playback Analogue Reality we'll need to wait until 1bit ---> 22,4MHz DSD A/D - D/A will be realized and made available . . . ?
But for now With my best wishes to Digital Designers who will be to first make an A/D - D/A with 256 x DSD resolution capabilities to Digitally record at least Classical HiRes DSD Sound material with a real recording richness of higher harmonic up to 100 KHz. (already possible on a Tim de Paravicini modded STUDER C37 - 1inch Reel Tape)
And Please don't dare to even think to compare any CD release no mater who ever made it with the sound of the Tim"s modded 1" - STUDER C37. . .if haven't heard it before...
Until then we have to wait a little . . . it'll be the same as to with current 4K video attempts and possible further UP resolutions . .. hopefully . ..
More of Tim Designs:HERE
Andreas
_____________________________________________________________
Here: some words from an interview with Mr. Tim de Paravicini
From Audio, January 1995
Tim de Paravicini, the Audio Interview: In Pursuit of Excellence
by Bruce Bartlett with Jenny Bartlett
Hidden away in a small company near Cambridge, England, is a man who upgrades analog tape recorders to near perfection. Tim de Paravicini modifies classic tape machines. He reworks them from the ground up, adding new tape heads, tweaking the transport, and replacing the electronics with his own custom tube designs. He also upgrades stereo microphones with special circuitry. And the results are worth it. His customers rave about the beautiful new sound, better than they can get with digital tape recorders.
An example of the de Paravicini sound is on A Meeting by the River, by Ry Cooder and Vishwa Bhatt. The experience of hearing this CD can be startling because of its presence, warmth, and purity. The recording won a Grammy for its engineering by Kavi Alexander of Water Lily Acoustics, an audiophile label. The electronics that contributed to this disc’s quality sound are the work of a man with a passion for audio purity that goes beyond digital quality. In fact, de Paravicini has contempt for digital sound as it now exists. He’s pushing the envelope far beyond what we ordinarily settle for in CD quality.
If you’re fascinated by the search for the ultimate in recording quality, de Paravicini’s story of modifications of recorders, consoles, and microphones will interest you, as will his provocative opinions on everything from digital sound to hi-fi "tweaks."
A man of many talents, de Paravicini is well known in esoteric audio circles as an extraordinary designer. While some of his circuit designs are tube and some transistor, all are original. He has been a consultant to Musical Fidelity and Lux Corporation in the design of many of their classic audio components.
Fourteen years ago, de Paravicini founded Esoteric Audio Research. The company makes vacuum-tube products for the high-end audio and pro-audio markets, such as power amplifiers, a microphone, a microphone amplifier, equalizers, and a compressor/limiter. With years of experience in disc cutting, de Paravicini has cut records for Water Lily Acoustics, Chesky Records, and Island Records. He also improved the performance of several recording lathes.
Although de Paravicini will upgrade any tape machine, his favorite is the legendary Studer C37. "It’s a good, reliable workhorse," he says. According to him, the C37 blows away everything else, even an Ampex MR70. The C37’s tube circuitry is simple, with no microprocessors to get in the way. Even before the upgrade, the C37’s specs are notable. The frequency response is rated as 20 Hz to 15 kHz, +1, -2 dB, and S/N is 75 dB (rms, weighted) at 15 ips. After de Paravicini’s modifications, the response is 7 Hz to 35 kHz, +/- 1 dB, and S/N is 90 dB!
One happy user of a de Paravicini tape deck is Chris Rice, owner of Altarus Records, a classical label. Rice had de Paravicini modify three Studer C37s - two 1-inch and one half-inch. "The heads were custom made to Tim’s specifications," says Rice. "The mechanical modifications he did himself. He stripped the electronics out and rebuilt his own circuitry into the existing modules, doing hundreds of modifications. He uses his own EQ curve. He also provides an AC mains regenerating power supply because the machines are not quartz locked; they depend on mains frequency. By doubling the capstan diameter, Tim doubled the tape speed from 7 1/2/15 ips to 15/30 ips."
According to Rice, "The new machines are incredibly stable mechanically. They sound fabulous, very quiet and more dynamic. They’re very clean and have no grungy noises. With the new Ampex 499 tape, the modulation noise is down so low, you can almost forget about it. It gives you quite a lot of leeway in your recording level. You don’t have to worry about compression because these tapes will happily go up to 9 dB over. The tape saturates way before the electronics overload."
Rice notes that his analog decks sound better to him than digital, even without any noise reduction. "They give a more accurate representation of what’s coming down the line. That has to be my final criterion: How closely can I capture what’s coming in from the microphones?"
Another satisfied user is Sam Rivers, a producer of jazz records. He sent de Paravicini two broken-down Studer A-80s to modify into a 1-inch and half-inch model. Vince Clark of Erasure also has one of de Paravicini's machines.
Kavi Alexander, the engineer with Water Lily Acoustics, won his Grammy for engineering a Ry Cooder album with a de Paravicini recorder; it was a 1-inch, two-track Studer C37. Alexander used a Blumlein stereo pair of custom microphones, which was built with rectangular mike capsules by Milab and with tube electronics by de Paravicini.
When I interviewed Tim de Paravicini, I was struck by his strong, original opinions about audio.
In some circles you have the reputation of a hi-fi tweak.
I'm not. I'm too academic to get into that. The hi-fi fraternity is bizarre, full of dangerous amateurs. I try to steer clear and do genuinely innovative work - something that's worthwhile.
What caused you to start modifying recorders?
I was dissatisfied with their performance, If "line out" doesn't sound like "line in," that's not good enough.
What’s the main advantage of your 1-inch analog recorder over digital recorders?
The sound quality. My analog recorder has four times the sampling frequency! The bias frequency is 160 kHz. The magnetic-particle flow past a playback head is equivalent to a 24-hit word, which is amazing resolution.
Analog recorders can sound wonderful, but DATs are so portable and convenient.
Oh, God, I hate DATs. Stopping and starting with those things is a pain in the ***. With an open-reel tape, you can pause it and go instantly; it's human; it's tactile. Whereas DATs stop, fit, fart, and think about what they're going to do - they're just not friendly. And unlike DAT tape, analog 1-inch tape archives beautifully. Some tapes made in 1955 are earthshakingly good. They still sound fresh. But talk to anybody with U-Matic tapes or DATs, and see how well they store. Run a DAT through a machine 20 times, and you're struggling.
If analog tape sounds so much better than digital, what improvements should be made in A/D, D/A converters?
First of all, the frequency response should extend from 3 Hz to 50 kHz, because we experience those frequency limits. We are able to detect audio up to 50 kHz. We don't hear it, but we experience it in other ways. I can give you tinnitus very quickly if I run an ultrasonic cleaner at 45 kHz. You are aware that it's on, and your ears ring when it's shut off. On the low end, we detect mechanical vibrations down to 3 Hz. When a marching band walks past you, you feel the drums in your stomach and bones. And that's all part of the sound.
Ten years ago in Stereophile, I said that digital was never going to work well in the chosen format. Digital should use a 400 kHz sampling rate and 24-bit words. Then it will satisfy the hearing mechanism and won't have a digital sound. Digital has a "sound" purely because it is based on lousy mathematics. The manufacturers presuppose too simplistic a view of our hearing mechanism.
But manufacturers don't want to change - it's the lowest-common-denominator syndrome. It's like 525-line television, which allows you only X amount of resolution. With digital, you've fixed your resolution parameters, where analog never had that problem.
I still do work on the vinyl record; it still can be advanced. The number of vinyl molecules passing the needle every second is equivalent to half a gigahertz. So there ain't a lot wrong with it, fundamentally. You can carry on improving it without losing compatibility. It's like good old 35-mm films - you carry on improving films, but there's nothing to stop you from shoving them through the same old projectors!
I've been pioneering work on a CD player that runs at 88k, but it only works with CDs that were cut at 88k.
When storage density increases enough, we won't have the excuse for using only 44.1k.
Right. The manufacturers should have said, "Let's go gung ho and create a real system that works right." A 12-inch LaserDisc would have given you an hour's worth of music to the highest standard. Manufacturers try to pretend that what's good enough for Joe Doe at $5 is the state of the art.
Getting back to your recorder mods, what transport modifications do you make?
Whatever makes the system more stable. Actually, wow and flutter is more limited by the tape than the transport. Tape is a mechanically compliant item, and 1-inch tape has much more tape stability and strength than quarter-inch. Yes, the wider tape costs more, but it's a small part of the total project cost.
How did you first learn about tape-head design?
I stripped a lot of machines on the market, worked out my own mathematics, and read papers by Jay McKnight, from Ampex, and so on. I ask the tape-head manufacturers, like Saki, to build heads to my specific requirements. I emphasize bass performance and the fineness of the laminations.
Do you recommend using Dolby SR with your machines?
No. It's unnecessary, and it doesn’t work well under dynamic piano conditions. It doesn't encode a control signal, so it can only approximate. The noise floor in my system is limited only by the microphone. You can't hear its tape hiss - just microphone hiss.
You use vacuum tubes in many of your designs. Some people have said that tubes have euphonic even-order harmonic distortion. Do you rely on this tube nonlinearity to achieve the sound of your mods, or do you always run the tubes in their linear region?
I do not rely on tube nonlinearity. I don't want a sound in my machines. What comes out must sound the same as what went in.
The "warmth" in a lot of tube electronics is due to their dismal top end, the bad transformers they use, and the loading down of their high-impedance outputs. Because of the output transformer and the feedback used, many tube circuits have a partial bass instability that gives a bloated bass. Any warmth in the tube sound is a defect, but listeners don't want to know that.
I don't have to use tubes in my designs; I only do it for marketing reasons. I've got an exact equivalent in solid state. I can make either type do the same job, and I have no preference. People can't pick which is which. And electrons have no memory of where they've been! The end result is what counts.
Most transistor-circuit architecture was different from tube-circuit architecture, and that's what people were hearing, more than the device itself. The main advantage of tubes is that an average tube has more gain than an average transistor. Second, tubes don't have the enormous storage times of transistors, so they are very fast. Tubes go to 100 MHz without trying.
Moving on to microphones, your mikes use rectangular diaphragms, tube electronics, and huge transformers. Why?
A circular diaphragm has one dominant resonant mode. But a rectangular diaphragm does not have the same resonant mode in both axes, so it tends to have a flatter response. Also, a rectangular diaphragm has less off-axis coloration in the horizontal plane than does a circular diaphragm of the same area.
My mikes are transformer-coupled, triode designs. The electronics have a frequency response of 5 Hz to 35 kHz (-1 dB).
I use transformers in my microphones because they can do the job better than anything else. There's no advantage in transformerless circuits because a lot of them can't drive long lines. As long as I know that the electronics of my microphone go from 3 Hz to 100 kHz at the end of 1,000 meters of cable, I'm all right.
Some transformerless mikes have pathetic headroom. Disgusting. We're besotted with this phantom-power philosophy. Most of the mikes draw only I damn milliamp at 48 volts, max. That's 48 mW of energy; it doesn't give you a lot of headroom. I want a mike that can shove 3 volts, +12 dBm, down a line, 20 to 20k, boom! Why so much voltage? Suppose you take a capacitor mike that produces 10-mV output with 74-dB SPL input. At 144 dB SPL, the mike will put out over 3 volts.
You've said that we experience sound down to 3 Hz, and that reproduction down to this frequency is essential. Do studio consoles go down that far?
No. The average console has all these cumulatively rubbish electronics in it. If you cascade 10 amplifiers, each with a response down 1 dB from 20 Hz to 20 kHz, you end up with a cumulative 10 dB down from 20 Hz to 20 kHz. So you must minimize all degradation. Since I use a lot of transformers in my stuff, each transformer must be very wideband.
Unfortunately, the average manufacturer looks at only one piece of equipment, in isolation. They quote a tape machine as having a response of 50 Hz to 15 kHz, +/- 1 dB, and say that's fine. Yes, in isolation. But not as a cumulative system. Tony Faulkner uses a mixing console of mine, full of tubes and transformers, but it's vastly flatter than most of the mixing consoles on the market.
What's your overall design philosophy?
Audio devices should not have a sound of their own; they should be virtually a black box. The results prove themselves in recordings using my products. They do the job.
Whatever the device is, I look at it and say, can that device be logically improved? Forget about cost. Companies like Neumann charge a lot of money, but I say, could they make that product a little better and charge a little more for it? Try to make things better, whether it's outrageous or not. Somebody will want it and will pay for it.
Any last words?
I try to provoke people. I'm sick and tired of the me-too factor, the lemming factor. Just because everybody else wants to jump off a cliff doesn't mean I have to.
Many audio companies tend to rest on their laurels and don't bother to take the next step forward. They should leap ahead instead of staying on the back burner. They have the potential to be stunning.
Discography
The two recordings below, among the finest-sounding available, were made with de Paravicini’s modified tape machines and microphones.
Ry Cooder/Vishwa Bhatt: A Meeting by the River, Water Lily Acoustics WLA-CS-29-CD. Kavi Alexander, producer. (Available from May Audio Marketing, P.O. Box 1048, Champlain, NY 12919; 800/422-7525). This beautiful blend of Western and Eastern acoustic music was Stereophile’s Recording of the Month, and was reviewed in April 1993. In my opinion, the highs are especially sweet and gentle. The sound just flows effortlessly into your ears. The only hiss you hear, which is slight, is that of the microphones.
Ustad Ali Akbar Khan, Indian Architexture. Water Lily Acoustics WLA-ES-20. Kavi Alexander and Sallie Reynolds, co-producers. (Available as a double LP from Finch & Marsh, 2457 Cascade Trail, Cool, CA 95614; 916/885-2279.)
The following four recordings, again with excellent sonics, were mastered by de Paravicini and John Dent at The Exchange on a custom-built, all-tube cutting system designed by de Paravicini.
Ravel, Daphnis et Chloe, Boston Symphony Orchestra, Charles Munch. Chesky RC15.
The Power of the Orchestra/Mussorsky, Royal Philharmonic Orchestra, Rene Liebowitz. Chesky RC30.
Clark Terry, Portraits. Chesky JR-2.
Ana Caram, Rio After Dark. Chesky JR-28.
I know it seems like everyone is pushing these dacs, what's next 64bit dac?
Andreas
Any last words?
Discography
Bird in the hand....
Well said Arthur,
Please keep this thread OT ie specific to the 16 bit R2R DAC that is fully developed and simply awaiting parts delivery for production.
Nikitas and Merlin....Personally I would like to fully evaluate the potential of this product before speculating about 2nd or 3rd generation versions.
A well developed "bird in the hand" is better than a 1,000 posts speculating on the hypothetical products that are not even on the drawing board.
I have zero interest in Tim P's refurbished tape machines, please don't clutter this thread with 1000'sof words of whatever your posts were about...Didn't waste my time reading them.
Cheers
Derek.
Probably very interesting for some people, but very off topic in this thread I think.
Best regards
Arthur.
Well said Arthur,
Cheers
Derek.
Time and a place....
For sure we all love to have fun, but there is a time and a place....
Soekris has put a lot of time, effort and money into developing a specific product and will be selling it as a commercial design from his site....This is not a thread for OT, fun or good old boys together lounge chat....
I can not speak for Soekris but I am pretty sure he will want to keep the thread OT with a view to a group buy. Ideas for future versions will be of interest, but if you put yourself in his position ....
The best way to kill a group buy is to allow wild speculation on " an improved mark 2 version" before Mk 1 is for sale.....
I am VERY interested in Soren's sign-magnitude R2R board. It could make a nice replacement for the custom NOS PCM1704K board which sits in between a 384K-capable XMOS async-USB>I2S WaveIO and a BJT/FET/JFET "discrete op-amp" output stage.
Certainly the price is terrific, and Mr. Kristensen has clearly drawn on his processional experience to think things out and make good design and layout choices.
But I have a few questions:
a) How can an R2R (even a sign-magnitude style) be monotonic to even 18 bits with just .01% resistors without hand matching/trimming? Would it not take something like 0.0001% or better to get the DNL down low enough?
b) Can you tell us more about the power supply on the board? It looks like you have built a entire SMPS (sans the transformer). Are there connector pins to allow a user to skip all that and provide their own, super-clean and isolated PS?
c) Other than stock availability and maybe price, is there a reason you chose the Silicon Labs Si514 over the equivalent functioning but lower phase noise Si570/571?
d) Are you still taking early reservations for boards from the first run? Where do we officially register to sign up for one? The sales@soekris.com e-mail? Or some other means?
Thank you in advance for your answers. I look forward to learning more about your design and availability.
Discussing DSD 256 in a R2R DAC thread seems a little silly, right?
The DAC used here can natively support DSD 256x so it is good to know of its all capabilities.
Andreas
Uh, no it can not do DSD at all. I wish you DSD people would leave this thread alone already!
- Vendor's Bazaar
- Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KHz
