Any kits for high quality simple preamp
Administrator
Joined 2007
Administrator
Joined 2007
This has a gain of 3. The opamp can be something like a TL072 or NE5532.
Rin defines the input impedance.
Rg sets the gain which is (Rf+Rg)/Rg
The zener sets a stable midpoint voltage to bias it all.
Administrator
Joined 2007
Thats brilliant Mooly, I could use one ne5532 and make dual amp. Where would be the best place for a trimmer pot to vary gain from 1 to 3, preferably twin gang if they exist. Things have moved on alot since I made anything.
The NE5532 and the LM4562 are probably the best of the standard "bjt" or normal transistor ones, other options would be the OPA2134, the OPA2604 or even the old TL072 (don't discount it until you have tried it)
Far from brilliant, not even quality. :shhh:
Its easy to criticise basic circuits... perhaps you could submit one of your own that meets the requirements.
You don't want to make an amplifier with variable gain, it's not good engineering practice. All you need is an attenuator at the pre-amp output - aka a volume control.
I'd tend to agree with that, however if you really want adjustable gain then making Rg variable (a dual 10k pot) is the way to do it. You would also need to add a series 470ohm or thereabouts to ensure the gain has a maximum absolute level when the pot is at minimum resistance.
Further refinements to the circuit would be the addition of an input RF filter. That would consist of a series input resistor and cap to ground.
This shows these parts added and also the combined response of the circuit. Depending on what the circuit feeds, a low value resistor in series with the output might be considered a good option. That would isolate the opamp output from capacitive loading and help ensure totally unconditional stability. 47 or 100 ohm is a suitable value. A small electrolytic cap of around 10uf across the supply pins of the opamp would take care of decoupling.
