FS: ICEPower 125ASX2 module
Well, usually we use 500ASP or 250ASP to driver 250A directly, haven't used individual smps to driver it, so really can't help you about this issue. maybe others have experienced it?
Thanks ghentxu. I see now from the ICEPower website how the 250ASP is used together with a 250A amp module for 2 or 3-way setups. Purchasing just the 250A modules limits my immediate options. I'll research on their website what DC voltages they recommend to adequately power just a 250A module. - Rick
I recently acquired cary caa 1 power which uses ice power module. Got the unit with non-working one channel (mono per module) and the power transformer also shorted. Emailed cary but didn't get a reply.
Found this thread in my search but seems the modules layout not the same with this model. Other manufacturers also used same module type like; Jeff Roland, bel canto, ps audio and d-sonic magnum.
Ghentxu or anyone can point me where to source replacement would be much appreciated.
Another question, any chance to fix the module? Thanks.
New DIY Chassis for NC400/NC1200/UcD700
Hi Everyone,
Here you are: Pair GK Ncore MX DIY Mono Case Kits for Hypex NC400 NC1200 UCD700 Ghentaudio | eBay
This GK-Ncore-MX Mono(XLR input) case-kit, is specific designed for multiple combination of Hypex modules:
  • NC400 + SMPS600
  • NC1200 + SMPS1200
  • UcD700 + SMPS1200
All needed installation holes of above modules have been pre-drilled in bottom-plate already
Greeting,
Ghent
