Vacuum Tube SPICE Models
6KT8
I've created a model for the triode of the 6KT8.
Code:
* Generic triode model: 6KT8-Triode
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Tue Jul 29 15:14:00 2014
*                   Plate
*                   | Grid
*                   | | Cathode
.SUBCKT 6KT8-Triode A G K
BGG   GG   0 V=V(G,K)+0.21127936
BM1   M1   0 V=(0.0039561161*(URAMP(V(A,K))+1e-10))^-0.75363001
BM2   M2   0 V=(0.66559284*(URAMP(V(GG)+URAMP(V(A,K))/84.529157)+1e-10))^2.25363
BP    P    0 V=0.0058042243*(URAMP(V(GG)+URAMP(V(A,K))/126.9983)+1e-10)^1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0034550891*V(M1)*V(M2)
BIG   IG   0 V=0.0029021122*URAMP(V(G,K))^1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK  A    K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.0029708017*URAMP(V(A,K))^1.5)))+1e-10*V(A,K)
BIGK  G    K I=V(IG)
* CAPS
CGA   G    A 3p
CGK   G    K 3.2p
CAK   A    K 1.6p
.ENDS
Could anyone create a model for the pentode? I can't get the knee sharp enough with Ayumi's method.
  • 6KT8.pdf
  • 6KT8T.csv.txt
I believe I have a good model for the pentode 6KT8
Code:
**** 6KT8P ******************************************
* Created on 07/31/2014 13:59 using paint_kit.jar 2.6
* www.dmitrynizh.com/tubeparams_image.htm
* Plate Curves image file: 6KT8P.png
* Data source link:
.SUBCKT PENT_6KT8P 1 2 3 4 ; P G K G2
+ PARAMS: CCG=7.5P  CGP=0.046P CCP=2.2P RGI=2000
+ MU=363.3 KG1=144.6 KP=83.7 KVB=7.13 EX=1.77 KG2=0.22
* Vp_MAX=500 Ip_MAX=35 Vg_step=0.5 Vg_start=0 Vg_count=8
* Rp=1600 Vg_ac=23.5 P_max=2.5 Vg_qui=-23.4 Vp_qui=240 UL=0.464 EG2=125
* X_MIN=45 Y_MIN=40 X_SIZE=531 Y_SIZE=370 FSZ_X=1044 FSZ_Y=696 XYGrid=false
* showLoadLine=n showIp=y isDHT=n isPP=n isAsymPP=n isUL=n showDissipLimit=y
* showIg1=n gridLevel2=n isInputSnapped=n
* XYProjections=n harmonicPlot=y harmonics=y
RE1  7 0  1MEG    ; DUMMY SO NODE 7 HAS 2 CONNECTIONS
E1   7 0  VALUE=  ; E1 BREAKS UP LONG EQUATION FOR G1.
+{V(4,3)/KP*LOG(1+EXP((1/MU+V(2,3)/V(4,3))*KP))}
G1   1 3  VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1*ATAN(V(1,3)/KVB)}
G2   4 3  VALUE={(EXP(EX*(LOG((V(4,3)/MU)+V(2,3)))))/KG2}
RCP  1 3  1G      ; FOR CONVERGENCE
C1   2 3  {CCG}    ; CATHODE-GRID 1
C2   1 2  {CGP}  ; GRID 1-PLATE
C3   1 3  {CCP}   ; CATHODE-PLATE
R1   2 5  {RGI}   ; FOR GRID CURRENT
D3   5 3  DX      ; FOR GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
This first two bias lines aren't exactly on, but I think it looks decent enough (though I'm still pretty new at this so I could be totally wrong.) :p
  • 6KT8.pdf
  • 6KT8P.inc.txt
Turns out the model I posted yesterday was actually pretty crappy lol. It didn't simulate in LTSpice at all and I had to tweak the subckt because the nodes didn't match up with the pentode/tetrode symbol I have. The model below is the tweaked one from the LTSpice picture, but I've attached the file that was generated by Paint_Kip if anyone wants to tweak it further.
Code:
* Created on 08/01/2014 09:21 using paint_kit.jar 2.6
* Data source link:
+ MU=10000 KG1=86.8 KP=96.3 KVB=5.63 EX=1.5 KG2=0.176
* Rp=7680 Vg_ac=5.88 P_max=2.5 Vg_qui=-0.292 Vp_qui=204 UL=4.51 EG2=125
* X_MIN=45 Y_MIN=39 X_SIZE=531 Y_SIZE=370 FSZ_X=1254 FSZ_Y=696 XYGrid=false
* showLoadLine=n showIp=n isDHT=n isPP=n isAsymPP=n isUL=n showDissipLimit=n
+{V(2,4)/KP*LOG(1+EXP((1/MU+V(3,4)/V(2,4))*KP))}
G1   1 4  VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1*ATAN(V(1,4)/KVB)}
G2   2 4  VALUE={(EXP(EX*(LOG((V(2,4)/MU)+V(3,4)))))/KG2}
RCP  1 4  1G      ; FOR CONVERGENCE
C1   3 4  {CCG}    ; CATHODE-GRID 1
C2   1 3  {CGP}  ; GRID 1-PLATE
C3   1 4  {CCP}   ; CATHODE-PLATE
R1   3 5  {RGI}   ; FOR GRID CURRENT
D3   5 4  DX      ; FOR GRID CURRENT
.ENDS
Besides the screen current this new model seems to be a keeper. :D
  • 6KT8P.inc.txt
  • 6KT8P_For_Paint_Kip.inc .txt
  • 6KT8.pdf
6ER5 Triode
Code:
* Generic triode model: 6ER5
* Version 3.10, Generated on Fri Aug  1 15:09:59 2014
*            Plate
*            | Grid
*            | | Cathode
.SUBCKT 6ER5 A G K
BGG   GG   0 V=V(G,K)+0.20684562
BM1   M1   0 V=(0.017253359*(URAMP(V(A,K))+1e-10))^-2.6665979
BM2   M2   0 V=(0.36000594*(URAMP(V(GG)+URAMP(V(A,K))/37.093881)+1e-10))^4.1665979
BP    P    0 V=0.0091669979*(URAMP(V(GG)+URAMP(V(A,K))/103.03686)+1e-10)^1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.042512831*V(M1)*V(M2)
BIG   IG   0 V=0.004583499*URAMP(V(G,K))^1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK  A    K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.0047172745*URAMP(V(A,K))^1.5)))+1e-10*V(A,K)
BIGK  G    K I=V(IG)
* CAPS
CGA   G    A 0.38p
CGK   G    K 4.4p
CAK   A    K 3p
.ENDS
  • 6ER5.inc.txt
  • 6ER5.pdf
  • 6ER5.csv.txt
6BS8
Code:
* Generic triode model: 6BS8
* Version 3.10, Generated on Fri Aug  1 16:29:30 2014
*            Plate
*            | Grid
*            | | Cathode
.SUBCKT 6BS8 A G K
BGG   GG   0 V=V(G,K)+0.1396991
BM1   M1   0 V=(0.010461639*(URAMP(V(A,K))+1e-10))^-0.68684648
BM2   M2   0 V=(0.6859192*(URAMP(V(GG)+URAMP(V(A,K))/30.02214)+1e-10))^2.1868465
BP    P    0 V=0.0046594327*(URAMP(V(GG)+URAMP(V(A,K))/43.769207)+1e-10)^1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0027247899*V(M1)*V(M2)
BIG   IG   0 V=0.0023297163*URAMP(V(G,K))^1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK  A    K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.0024903068*URAMP(V(A,K))^1.5)))+1e-10*V(A,K)
BIGK  G    K I=V(IG)
* CAPS
CGA   G    A 1.15p
CGK   G    K 2.6p
CAK   A    K 1.3p
.ENDS
  • 6BS8.csv.txt
  • 6BS8.pdf
  • 6BS8.inc.txt
FYI....
It would seem that Mouser electronics has a new spice simulator coming out. It does simulations, has 100K parts inventory, pcb layout, and integrates the BOM into your mouser cart. I signed up for the notification of release and it will be really interesting to see if our tube models will work with this.
FYI....
Interesting. Do you have a link on the Mouser site?
I installed tried to use the Ayumi models with LTSpice.
I replaced in all the ".mod" files each "^" with "**".
LTSpice gives the following error message for 2A3 and others:
WARNING: Can't resolve .param gg=(v(g,k)+-0.47258991)
Looking in the "2A3.mod" file, I find the offending line:
It seems that LTSpice doesn't like it: maybe a parameter cannot depend on a voltage like v(g,k) ?
Does anyone have a fix for this ?
Joined 2004
Is this the original Ayumi model?
* Generic triode model: 2A3
* Copyright 2003--2006 by Ayumi Nakabayashi, All rights reserved.
* Version 3.01, Generated on Wed Mar 22 17:19:23 2006
.SUBCKT 2A3 A G K
BGG GG 0 V=V(G,K)+-0.47258991
BEP EP 0 V=URAMP(V(A,K))+1e-10
BEG EG 0 V=URAMP(V(G,K))+1e-10
BM1 M1 0 V=(0.056835059*(URAMP(V(EP)-1e-10)+1e-10))^-0.4044593
BM2 M2 0 V=(0.78762513*(URAMP(V(GG)+V(EP)/3.7366878)+1e-10))^1.9044593
BP P 0 V=0.0012053852*(URAMP(V(GG)+V(EP)/4.7442465)+1e-10)^1.5
BIK IK 0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.000709416*V(M1)*V(M2)
BIG IG 0 V=0.00060269261*V(EG)^1.5*(V(EG)/(V(EP)+V(EG))*1.2+0.4)
BIAK A K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.0010032299*V(EP)^1.5)))+1e-10*V(A,K)
BIGK G K I=V(IG)
* CAPS
CGA G A 16.5p
CGK G K 7.5p
CAK A K 5.5p
.ENDS"
Change all "^" to"**".
.SUBCKT 2A3 A G K
BM1 M1 0 V=(0.056835059*(URAMP(V(EP)-1e-10)+1e-10))**-0.4044593
BM2 M2 0 V=(0.78762513*(URAMP(V(GG)+V(EP)/3.7366878)+1e-10))**1.9044593
BP P 0 V=0.0012053852*(URAMP(V(GG)+V(EP)/4.7442465)+1e-10)**1.5
BIG IG 0 V=0.00060269261*V(EG)**1.5*(V(EG)/(V(EP)+V(EG))*1.2+0.4)
BIAK A K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.0010032299*V(EP)**1.5)))+1e-10*V(A,K)
BIGK G K I=V(IG)
* CAPS
CGA G A 16.5p
CGK G K 7.5p
CAK A K 5.5p
.ENDS"
Yes... use the "xxx.inc" files in LTspice. ;)
