How to change active xover frecuencies
Joined 2009
How to change active xover frecuencies of Reckhorm F1 active xover, now the high cut adjustable 30-100Hz, low cut adjustable 50-100Hz.
I want to filter tweeter Seas Millenium TCF002 with a low cut filter 1.000Hz and advice for high cut filter for SS18W8545-00
Attached pics with schematic & manual.
All help will welcome.
TIA
Felipe
  • RECKHORM F1 ACTIVE XOVER manual_web.pdf
Joined 2009
Technical data:
power supply 230 volts / 50 Hz or 110 volts / 60 Hz
input sensitivity 0.1 - 10 volts / 10 k ohms
satellite stereo signal output + 3 dB / 47 k ohms
satellite frequency response 50 - 40000 Hz -1 dB
satellite high pass, stereo, variabel 50 - 150 Hz / 24 dB
satellite total distortions 0.001 %
subwoofer 2 x mono signal outputs max. 10 volts / 47 k ohms
subwoofer frequency response 15 - 150 Hz -1 dB
subwoofer 2 x mono low pass variabel 40 - 150 Hz / 24 dB
subwoofer total distortions 0.001 %
signal - noise ratio subwoofer and satellites over 95 dB
power consumption with signal input max. 3 watts
power consumtion without signal max. 2.5 watts
width x height x depth (mm) 155 x 48 x 130
weight 0.7 kg
