Trio subwoofer...
Have a look at this design - simple 3x12" subwoofer capable (on paper) of just over 126dB @ 700W in its passband from a box that's just around 7.5 cu.ft. or so. Total driver cost is around $285 (less if you build two or more subs).
What do you think? Feasible, or there are cheaper and easier ways of getting to the same output levels with the same F3 point?
Well, just looking at Small's vented box efficiency chart, a ~7.5 ft^3/40 Hz F3 is maxed out at 5%, so short of finding cheaper drivers, probably not without designing to a narrower BW with fewer drivers.
GM
Good stuff. I thought it looked pretty good on paper. 126dB of linear output, F3 of 40 Hz and a box that's around 7.5 cu.ft. in size, for $285 in drivers.
What is group delay on this design compared a TH with similar output?
It hits about 12 ms @ 40 Hz, which isn't too bad at all. See first image
Concerning a comparison to a TH, that would depend on the design of the TH. I think it should compare very well though. Second image shows the predicted group delay for my POC #3 TH, which has a similar cutoff point.
