Disabled Account
Joined 2012
Richard, most of the consumer stuff users the cheap resin bonded paper with very thin copper foil.
If you have ever worked on a Marantz consumer product, you will know what I mean. The boards only tolerate 1 soldering operation.
I did work on a Marantz -- installing IC sockets. That was what made me ask the question of how thin it is typically. I'll do some tests and report what affect thin copper has vs 1-2 oz copper.
[BTW - I dont build audio circuits with smd parts.... dont see any reason to do so. Offers me no sonic advantage and a lot of head-aches.]
THx-RNMarsh
Thanks Dan for offering your insight.
For the record, I certainly don't put any 'blame' on Dimitri for doing the compilation of my internet comments. I don't remember even making them, or who opposed them, but I have been offering them to those who would listen, for about 25 years, now, even before the internet got popular, on a network called TAN. Dimitri just gathered them up, and did a very good job in organizing them into something understandable, when they started as a great number of individual inputs, at different times, and perhaps different locations. It is amazing that it is even readable. It is not easily readable by the novice engineer, I am told, and there is not much I can do about that.
A stirling effort by Dimitri then ;), and thanks to you both for putting such information in usefully available form.
I would not expect a novice engineer without proper exposure to real world professional audio to make head or tails of much of what you discuss in the pdf.
For the record, my father is similar age to you John (only recently retired), and has been written up as the icon of the Australian radio broadcast industry....we play in his garage and I get to hear many stories of how things were done.
The SSM2142 audio balanced line driver was drunkenly conceived on a paper napkin in a Dallas bar....my father explained what was needed and how to do it....three weeks later Derek Bower sent my father initial examples.
That product went on to become highly popular in the professional audio world.
Sometimes it is the new dog teaching the old dog (concepts parallel to BQP and other stuff), but not always....we have beery intelligent relaxed technical discussions, and I get plenty of interesting technical tips as I have gotten from you.
He has threatened to write a book of industry memoirs....with Dimitri's effort you are half way there.....I am sure you could put something together, all you need is a Dictaphone.
Dan.
BTW, I took your 'don't blame me' quip as humorous tongue in cheek.....it's a sad pity that at least one member elected not to see it that way.
AX tech editor
Joined 2002
"You CANNOT 'accidently' make a breakthrough unless you pretty well know what you're talking about."
Clearly then those prehistoric hunters who invented the atlatl understood in detail the science of levers, force vectors and MV^2.
You are very tiring. Do you think this thing was invented by someone who never hunted, never thought about how to kill a prey, never speculated 'if I only could do it from farther away'? Basic R&D my friend.
jan
I Should Have Patented This....
Vacuum desoldering irons are recipe for damaging modern (and old) consumer boards.
I use a spring desolder pump....the trick is to shorten the teflon tip by 3mm or so, and then fit a 10mm or so length of 1/4'' silicone tubing over the teflon so that it protrudes by 3mm or so.
This gives a heatproof resilient compliant tip that prevents the recoil from shifting the copper traces/pads, and provides perfect seal sucking all solder away from the joint.
Apply liberal new solder and flux beforehand.
The silicone tubing end will last a couple of thousand joints...just trim it back 3mm or so and you are good for another couple of thousand desolders.
Lube the internals of the solder sucker with Mr Sheen or Marveer wax polish....prevents solder particles sticking internally.
I have reworked hundreds of thousands (millions ?) of joints this way and have never lifted/shifted a track/pad since adopting this method.
Aeromodel shops sell it as fuel tubing.
Dan.
There was undoubtedly an evolutionary process in its development, and the final form(s) was/were the result of endless variation, trial-and-error, and ruthless selection (the "error" part often did not end well) over generations. Thus was all early development.
In the past century or two, with a basic understanding of how the material world works used as a starting point, the climb up the technological curve has been orders of magnitude steeper- and I think you understand why.
We all stand on the backs of those that came before us. Whatever field we work in to disregard what has come before whether good or bad would be rather silly. In this realm we are happy to look back at things that John and many others have created and use those basic designs to move forward and create something new where it is desired. Without those who came before you have to start with nothing, a very difficult place to be for sure.
I imagine that the precursor to the boomerang was a rock or a stick. I'm going to eat and I want to kill that animal, I can throw a rock from over here and if I miss I can run! Then perhaps a big stick and on from there. An evolution of design from a basic necessity of wanting to survive by eating! So many starts to things were just simple observation but from there you have to have a basic understanding of how something actually works to understand and move forward.
SY's example like the discovery of polycarbonate plastic are found through serendipity but at the same time the person who discovered polycarbonate did have a basic intent to do something, it just wasn't what was originally the desired result. A mistake was recognized as something useful and then the real work begins.
AX tech editor
Joined 2002
Actually I don't believe you need to have a detailed understanding how something works to be able to recognise it's utility and use it, even refine it. I doubt that those hunters knew about gravity and aerodynamics and kinetic energy in any significant way.
An example: you must have seen outfielders (right name?) catch a ball; do they do any advanced calculus to calculate where it will land, and then move to that position?
No - the ONLY trick is to make sure that the angle under which you see the ball does not change. If you do that, the ball ends up in your hand. Very easy.
Do they know this? Most did not - they just did it!
Jan
They did NOT start by trying to make Teflon. It was an accident that they decided to investigate, rather than throwing the result away.
Thank you. That is very helpful info. No wonder their traces lift so easily when replacing parts!!
I'll use info and try to get some samples and do tests with the the standard quality thickness.
Where can I get samples of blank pcb of these thicknesses?
-Richard
Frankly, no idea, Richard. Remember, I live in Serbia.
I have a man doing the PCB for me, and he does all the purchasing. Currently, the best he has is 50 microns, I'm not very happy with that, I'd prefer 7 microns, but right now, it seems I don't have a choice.
I would suggest you fing a PCB printing/drilling service near you, go there and ask them for samples, they always have leftovers, cutouts, etc, if you just want to satisfy your curiosity. Or they can cut more serious pieces for you usually on the spot, depending on what you want.
I get your point, but I don't think it is correct. You CANNOT 'accidently' make a breakthrough unless you pretty well know what you're talking about.
Your example for AGB is a point in case - do you think if I had been in my shed and accidently spilled some coffee I could have invented the phone??
Some insights and progress can and often is made by unintended or lucky things, but that's only helping or speeding it up. Myriad are the cases where you just missed something that would have brought you forward but had to find at a later stage. Same difference.
Jan
Jan, with all respect, I think you are looking at it far too technically. While in technology you are probably quite right, do remember that Alexander Fleming did discover panicillin quite by accident, he simply forgot to put a plate back in the fridge, and it turned kinda green by the morning he was back in the lab.
Do you really think one of our ancestors thought out a scientific test to create wine from grape juice? Or vinegar from wine? Or create penicillin crossed hard cheese you Dutch are such masters of (I wouldn't be caught dead without some Old Amsterdam cheese in my fridge!)?
Discovering new Saturn moons is another matter, that is, as you say, hard science and no accident.
AX tech editor
Joined 2002
If you leave a plate out and it turns green do you leap to the conclusion that you have discovered a new medicine?
Edit: the point is not that accidental discoveries are not made. The point is that such an accidental or serendipity only happens to those that know the field, know the details and recognise the lucky shot for what it is. SY's example is a good one: the guy who made the 'accident' happen had no clue - it was the experts in the field that recognised it for what it was.
Jan
