100W Ultimate Fidelity Amplifier
Bias current is to high over 120mA, set 8mV at 0R22, and use proper heatsink.
Thank Mr.mile for quick response..
can i use this scheme for set bias?
ok this morning i will try use this scheme and replace 2k2 with 4k7 trimpot..
thank a lot Mr.Mile
I tried pcb green.(cloned.).You will find it if you search for " apex ax11 " ...
Sound is ok for its simplicity. Mine (pcb-s) are 50X60mm each one.
Pre-finals transistors are only warm -no heatsink on. Just tested it today.:)
HI Cook77
for PCB layout which software are you used. I am using sprint layout but some component not macing please help me. and how to print exact size on A4 page because my layout output is bit small after print.
HI Cook77
This one is meant to be for tests, so I used a permanent marker. The most of my pcb are made like that. Lately I made some by p&p method. Just measure some transistors size and match it in the picture of the pcb . If it fits, than that is the size of the pcb....
